Do you need a press to do a rear wheel bearing on a dc?
Old 04-16-2010, 09:50 AM
tothewall's Avatar
Default Do you need a press to do a rear wheel bearing on a dc?
ssia
Old 04-16-2010, 03:24 PM
tothewall's Avatar
Default Re: Do you need a press to do a rear wheel bearing on a dc?
top
Old 04-16-2010, 03:37 PM
jimmy o.'s Avatar
just do what i did take your hub to a shop and have them press in the bearing
Old 04-16-2010, 03:39 PM
DAintegraGSR's Avatar
i dont belive you do.. should be 4 bolts on the back side of the hub...(i know it was when i did my ej1 a few months ago. just unbolt pull out the hub bearing/spindle and replace with new one...
Old 04-16-2010, 03:41 PM
jimmy o.'s Avatar
oh i thought he said front lol my bad ive never done a rear one
Old 04-16-2010, 04:09 PM
tothewall's Avatar
In the manual it looks like there's just the spindle nut holding the hub assembly on and I'm replacing the whole thing. I was jw if the assembly needed to be pressed in for the proper fit or if just torquing the spindle nut would seat it properly.
edit: and the acura shop manual says nothing about pressing the assembly in or out. If you needed a press if would state that explicitly, right? Just double checking because I only have so much use of a lift and if this turns into a project I'm SOL.
MarkCayabyab
10-07-2017 11:40 AM
eg:R
10
10-15-2011 02:15 PM
PaChiLa Leader
02-18-2009 05:21 PM
typertn
11-23-2003 11:30 PM
pcorad
05-30-2002 12:36 PM
Quick Reply: Do you need a press to do a rear wheel bearing on a dc?
