Do I need new gaskets??
Old Feb 25, 2002 | 11:11 AM
dlslvtch21's Avatar
Default Do I need new gaskets??
just purchased Comptech 4-2-1 header and catback exhaust, are there any gaskets or anything that I will need to purchase, or can I use the stock gaskets. The car is a 99 GSR w/ 35,000 miles on it. Thanks again...
Old Feb 25, 2002 | 11:14 AM
itr0045's Avatar
Default Re: Do I need new gaskets?? (dlslvtch21)
You should be fine with the stock ones. Everything you need will come with the parts.
Old Feb 25, 2002 | 03:44 PM
threatcon13's Avatar
New User
Default Re: Do I need new gaskets?? (itr0045)
stock gaskets are fine for the header. exhaust will come with gasket/s. (same thing as dls said)
Old Feb 26, 2002 | 05:22 AM
dlslvtch21's Avatar
Default Re: Do I need new gaskets?? (ALLMOTORDC2)
Now I bought the header and exhaust used, can I use all the stock parts or do I need to go out and buy anything??
Old Feb 26, 2002 | 05:26 AM
shamoo's Avatar
Will you make something up for me please?
There should be a gasket/donut ring between the two parts of the header. You can reuse your stock header gasket and spray some copper sealant in there if ya want. Everything should be fine.
Good luck.
Old Feb 26, 2002 | 07:10 AM
Fooser's Avatar
Default Re: Do I need new gaskets?? (shamoo)
the header ghasket dosent cost that much. probably like $10. I would just pick a new one up cause your messing around with that area pulling off stock header. could mess up the old one. get a new one and install it when you put the header on.
newbie007
Sep 3, 2012 04:55 PM
pdevilk
Mar 11, 2012 05:07 PM
Xtream_V
Nov 17, 2010 08:39 AM
97CivicDad
Jul 25, 2006 06:33 PM
stiness101
Jan 11, 2006 10:12 AM
