Do clusters go bad?
Old Feb 9, 2015 | 12:58 PM
fernando.'s Avatar
Default Do clusters go bad?
I have a 2000 GSR all stock (motor wise) with a new OEM Honda thermostat, rad, water pump and sending unit. The temperature gauge fluctuates randomly and doesn't read correctly but it never goes past half. I've hooked up my own scan tool while driving around and the water temp stays at a steady 180F no matter how/where I drive, I also verified this with our Honda HDS at work.
So my question is do the clusters go bad?
The only reason why it's baffling me is if I unplug the connector at the sending unit, the gauge goes to C and if I ground it, the gauge goes to H, so it seems like it's working still.
Old Feb 10, 2015 | 01:27 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Do clusters go bad?
yea they can go bad. try a different cluster. The temp gauge may be bad.
Old Feb 10, 2015 | 01:33 PM
fernando.'s Avatar
Found a ground screw loose on the back of the cluster that holds the green metallic film on, we'll see tomorrow if it fixes it.
I also cleaned off the crusty ground at the thermostat housing.
Old Feb 11, 2015 | 08:47 PM
Jimmy's Avatar
Global Moderator
Most likely that's the issue.. given my issues i have had with a type r cluster i purchased it had a bad fuel gauge.. I was reading somewhere where it says the life span of things that make the ''cluster'' work.. I'll see if i can pull up the thread
Cool thing is.. you can pick up just a gauge from acura automotive parts, if you need to.
Old Feb 11, 2015 | 08:52 PM
the171's Avatar
Any of the solder connections can crack causing strange behaviour.
Old Feb 12, 2015 | 05:33 AM
fernando.'s Avatar
Yeah one of the ground screws on the back of the cluster was backed off for some reason. Tightened it up and it's been perfect since.
Old Feb 12, 2015 | 10:48 AM
wunfstgsr's Avatar
Loved
Community Favorite
Probably from vibrations maybe.
dglassmyer
Apr 27, 2010 08:14 PM
zippakilla
Feb 21, 2009 11:02 AM
Dense
10
Jan 2, 2008 07:46 PM
ITR1071
Jun 20, 2002 12:40 PM
