Dizzy/Timing problem on a B18A
The wiring on my distributor was hacked up so I pulled it and was about to swap it for a new one.
The problem is, I forgot to check what direction the rotor was pointing when I pulled the old one.
So with the engine at TDC, what direction should the rotor be facing?
It's possible to install the dizzy 180 degrees off, so I need to know what cylinder the rotor should be pointing towards when the engine is at TDC.
Pele
Nov 30, 2002 01:04 AM
