distributor problem
Old Nov 25, 2008 | 06:30 PM
nanagsr's Avatar
Icon2 distributor problem
have a question for the broad well any obd1 dizzy non v-tec work on a v-tec motor????? I know the mounts are different but if slice of and bolt on well run the same?
Old Nov 25, 2008 | 07:16 PM
weavertime1's Avatar
I believe B18B1 dizzy will work by using two bolts, and cutting an ear off or something. I do not recommend this, but I gave you an honest answer. Good luck!
Old Nov 25, 2008 | 07:33 PM
delbert's Avatar
thats true. but i wouldn't try it. i would rather just go buy a new one or find someone with one around town
Old Nov 26, 2008 | 06:28 AM
twentyhurtz's Avatar
i wouldn't try it either, and because one motor is made to rev higher than the other, some internal components may be different, not sure.
Old Nov 26, 2008 | 06:38 AM
AlphaQup's Avatar
OBD1 LS dizzy going onto an OBD1 VTEC motor is fine. An LS dizzy will serve the same function. Like stated above, you have to cut off the forward leg because that's where the vtec solenoid is located on your vtec head.
The drawbacks: It can only be held down with the top bolt and I've heard you don't have the full range in adjusting your timing (correct me if I'm wrong anyone) as you would with a proper fitting vtec dizzy.
Old Nov 26, 2008 | 07:41 AM
Exactly!
Old Nov 26, 2008 | 07:42 AM
EmminoDaGreat's Avatar
Im sure it could work, I have used a d series dizzy to run a gsr, lol, but I had to hold it in place!!
Old Nov 26, 2008 | 06:29 PM
nanagsr's Avatar
thanks guys...
b00stedOne
Apr 8, 2010 04:50 PM
madmike84
13
Jul 11, 2009 07:44 AM
Sic_DA_Nine
Apr 12, 2008 09:02 AM
GsR92HaTcH
Jul 26, 2007 02:14 PM
Speed94
Mar 18, 2005 08:19 PM
