distributor for lsvtec
Old Jun 29, 2006 | 03:12 PM
lsvtecna's Avatar
Default distributor for lsvtec
hey guy im about to build my ls vtec setup which contains a jdm b16a head which i think is obd0 and 1997 bottom ls block....my question is if i can use my ls distributor with the head or do i have to use any vtec distributor?
Old Jun 29, 2006 | 04:52 PM
akstunt600's Avatar
yes, but you have to cut the right side of the dizzy's ear< where the bolt goes on the bottom right and grind off the stupid little box type portrusion.
i just did this today on a swapped integ, he put a full b16 swap and bought a t3/t4 and put in a 4 dr, and didnt want to buy a new dizzy.
Old Jun 29, 2006 | 07:29 PM
mr.beeks's Avatar
Default Re: distributor for lsvtec (lsvtecna)
what ecu are you using?????
Old Jun 29, 2006 | 09:41 PM
lsvtecna's Avatar
Default Re: distributor for lsvtec (mr.beeks)
im using a p28 ecu chipped and the distributor im going to use is 1997 ls which is obd2 but i heard that u have to use the same obd as the ecu is that right?
Old Jun 29, 2006 | 11:01 PM
mxl36o's Avatar
I have an OBD1 dizzy from 94 GSR, needs coil. Coil can be bought on ebay for less than $15. Selling mine for $70 shipped
Old Jun 29, 2006 | 11:04 PM
Takumi Fujiwara's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecna &raquo;</TD></TR><TR><TD CLASS="quote">im using a p28 ecu chipped and the distributor im going to use is 1997 ls which is obd2 but i heard that u have to use the same obd as the ecu is that right?</TD></TR></TABLE>
You can use the OBDII dizzy with the OBDI ECU, you just have to rearrange some pins. I can't find the thread that discusses it right now, and I don't remember... sorry!
Old Jun 30, 2006 | 03:14 AM
mr.beeks's Avatar
Default Re: (mxl36o)
use the 94 gsr distributor and take the coil from the 96ls dist.
the 97 distributor does not have the crank position sensor in it.
Old Jun 30, 2006 | 08:21 AM
mxl36o's Avatar
sooo buy my dizzy!
Old Jul 4, 2006 | 06:22 PM
bambam's Avatar
Default Re: (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">use the 94 gsr distributor and take the coil from the 96ls dist.
the 97 distributor does not have the crank position sensor in it.</TD></TR></TABLE>
this guys an idiot, don't listen to him. It does have the crank position sensor in it. You can use the obd2 ls dizzy just fine, just cut off the front leg.
alperx
Jan 23, 2011 01:29 PM
ls_bitik
Sep 23, 2007 09:59 PM
Iwant2run13s
Sep 21, 2007 06:07 PM
fast90hatch
33
Nov 30, 2004 09:23 PM
GWInquisitor14
Oct 29, 2004 04:13 PM
