difficulty to put in camber kit
Old Mar 7, 2003 | 01:35 PM
1hotintegra's Avatar
Default difficulty to put in camber kit
how hard is it to put in camber kit?? front and back???
Old Mar 7, 2003 | 02:26 PM
Default Re: difficulty to put in camber kit (1hotintegra)
ttt
Old Mar 7, 2003 | 03:30 PM
1bar's Avatar
ITs easy, when you are doing (if using air tools) make sure u dont crossthread the a arm joint. The back is very easy. After your done get it aligned right away my toe was so bad my tires where like this \ /
Old Mar 7, 2003 | 04:01 PM
tC_Dragon's Avatar
Default Re: difficulty to put in camber kit (1bar)
what camber kit are u referring to? if skunk2... IM me.
Old Apr 6, 2004 | 03:56 PM
JBBNJ609's Avatar
Default Re: difficulty to put in camber kit (pdcdragon)
how do you do it with an Acura Ingalls Front Camber Kit thats what i have
Old Apr 7, 2004 | 05:05 AM
Xsi's Avatar
Xsi
Not too difficult: http://www.integra.orcon.net.nz/camber
Old Apr 7, 2004 | 05:33 AM
Creep's Avatar
Default Re: (Xsi)
3/10 difficulty. Take it easy, driving to the alignment shop
after the install.
Old Apr 7, 2004 | 09:04 AM
zilverz's Avatar
Default Re: difficulty to put in camber kit (jason bouchard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard &raquo;</TD></TR><TR><TD CLASS="quote">how do you do it with an Acura Ingalls Front Camber Kit thats what i have </TD></TR></TABLE>
I did mine... when you get into it .. you will see there is a piece that connects 2 pieces together and runs BEHIND the spring ... you have to bend and twist it to get it out ... it took me serveral hours to do front and back ingalls .. i think i ended up using a jack to help me get the rears on
Old Apr 8, 2004 | 03:30 AM
Xsi's Avatar
Xsi
You mean the metal bridge? On my teg I took the whole thing out along with the two anchors then hit it off with a hammer
Old Apr 8, 2004 | 03:12 PM
zilverz's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">You mean the metal bridge? On my teg I took the whole thing out along with the two anchors then hit it off with a hammer</TD></TR></TABLE>
well im not sure if your 90 teg is the same as a g3 95 but yea it was like a metal bridge..
Old Apr 12, 2004 | 03:17 AM
JBBNJ609's Avatar
Default Re: (zilverz)
does any one have any pics that are gen 3 specific i love pics
Old Apr 12, 2004 | 03:59 AM
Xsi's Avatar
Xsi
I'm sure it's much the same, even without pics it's a pretty easy job. Removing the bridge is the most difficult part especially if you can't get it off the car. I managed to wiggle it off in one piece on my g2 so I could get a hammer onto it.
Old Apr 12, 2004 | 04:18 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar &raquo;</TD></TR><TR><TD CLASS="quote">ITs easy, when you are doing (if using air tools) make sure u dont crossthread the a arm joint. The back is very easy. After your done get it aligned right away my toe was so bad my tires where like this \ / </TD></TR></TABLE>
If you get an alignment in the first place, after changing the ride height of the car, chances are you probably don't really need a camber kit, unless you want to ADD negative camber or dial it in to a certain setting for track purposes.
Old Apr 12, 2004 | 05:25 AM
JBBNJ609's Avatar
Default Re: difficulty to put in camber kit (PatrickGSR94)
yea well my car has been in a frontal acident , so my camber is off and BAD , and my car is lowered as well
i will be putting on the kit in the next few days and then straight to the alignment shop
b16avtecinteg
Suspension & Brakes
Feb 2, 2008 03:47 AM
bmoua
Suspension & Brakes
Oct 19, 2007 04:00 AM
vtec8804
Suspension & Brakes
17
Aug 23, 2007 12:55 PM
legacyspecb
Honda Civic (2001 - 2005)
Jul 22, 2007 06:16 AM
JDMTurboEG6
Mar 11, 2004 07:53 PM
