Differences between integra models
Old Oct 8, 2002 | 06:59 PM
Dokta's Avatar
Default Differences between integra models
Does anyone know of a site where I can find all of the differences between the 3rd gen (94-01) integra models. For example, I want to know if the brake discs from a GS-R are different from an LS. I basically want to know the differences between the suspension systems, brake systems, engine/transmissions, and chassis.
I am planning on trading in my Civic Si for an Integra and I'm trying to find out what model to get. I will be getting rid of the engine in the Teg and installing my CRV-tec. I just need to know what the differences between all the components of all the models are because the car will be coming almost entirely apart and rebuilt with performance parts. Im trying to decide which parts I replace and which I keep stock, but that depends on which model I purchase.
Old Oct 8, 2002 | 07:05 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Differences between integra models (Dokta)
http://carpoint.msn.com
Old Oct 8, 2002 | 07:20 PM
Dokta's Avatar
Default Re: Differences between integra models (dLo GSR)
Thanks, but that doesn't help much at all. I need a site that has solid technical data that I can use to compare the different models and years of the 3rd generation integra.
Old Oct 8, 2002 | 07:39 PM
FourDoorGSR's Avatar
Heres a little starter info...
http://sport-sedans.tripod.com/teg_specs.htm
Old Oct 16, 2002 | 07:10 PM
Dokta's Avatar
Default Re: Differences between integra models (FourDoorGSR)
OK, how about this...
What are the differences between the suspension (springs, shocks, geometry, etc.) on a 1998 integra LS, an integra GSR, and an integra Type-R?
What are the differences between the brakes (rotors, pads, cylinder, pistons, lines, etc.) on a 1998 integra LS, an integra GSR, and an integra Type-R?
What are the differences between the clutch and flywheel from a 1998 integra LS, an integra GSR, and an integra Type-R?
Old Oct 16, 2002 | 08:32 PM
94teggyls's Avatar
maybe this will help http://carpoint.msn.com/compare/choo...2=1309&pt=used
Old Oct 17, 2002 | 12:14 PM
Dokta's Avatar
Default Re: Differences between integra models (94teggyls)
I have trouble believing that no-one on the integra forum has any technical knowledge about their cars. Is this forum full of teenaged ricers who get all their information from carpoint.com and honda dealerships and only know about paint codes, body kits, spoilers, and lights? Or does someone here have any real practical experienced based technical knowledge about these vehicles. I wonder whats going on at honda-acura.net
Old Oct 17, 2002 | 12:26 PM
timmy8151's Avatar
here you go:
http://team-integra.net/sections/art...p?ArticleID=43
Also, stop being a b*tch.
Old Oct 17, 2002 | 12:40 PM
Dirty GS-R's Avatar
New User
Default Re: Differences between integra models (timmy8151)
go cry somewhere else or do an f-ing search. you expect someone to take that much time to write down all the specs to every bloody integra because you are too lazy to find it yourself. have fun at honda-acura.net.
Old Oct 17, 2002 | 12:45 PM
Understeer's Avatar
Default Re: Differences between integra models (Dirty GS-R)
I know most of the specs and differences between them, but I ain't going to write a long post about it.
http://www.itrsport.com
Go to specifications.
LS/GS/GSR all have the same front/rear brakes, all use 14mm rear sway bar.
Type R has 22mm rear sway bar, 24mm front sway bar, trunk bar, tie bar, reinforced chassis.
dorkjoey
Sep 17, 2006 09:39 AM
chrisnova
Dec 9, 2004 05:48 AM
SilviaTypeR
Feb 11, 2004 07:02 PM
JDMThoughts
Jan 30, 2004 08:38 AM
