difference in lug pattern
Old Feb 17, 2011 | 03:19 PM
fredfifty's Avatar
Default difference in lug pattern
so i have a 4 by 114mm lug pattern, is that any good. does it have weaknesses or strengths? more rim availability?
im very new to fwd cars lol
Old Feb 17, 2011 | 03:42 PM
AntiRic3r's Avatar
Default Re: difference in lug pattern
I wouldn't say it's really better or worse, just something to be mindful of when buying wheels. That said, a lot of wheels have 2 sets of holes, one for 4x100 and one for 4x114.3.
Old Feb 17, 2011 | 04:30 PM
BlueIntegraBoy's Avatar
If this is a 96 spec ITR suspension, you'll have more difficulty finding replacement rotors when time comes. It is the same sized brakes as any other non-ITR Integra, so there's no benefit. As far as wheel selection, I would believe that the availability is less.
Old Feb 18, 2011 | 09:33 AM
fredfifty's Avatar
thanks, so theres 3 patterns-4x100, 4x114, and 4x114.3? i was told i have the same pattern as an accord? true?
Old Feb 18, 2011 | 09:58 AM
mafia's Avatar
accord and Integra lug patterns are different. Unless maybe you have Type-r 4 lug (im not sure what the R patters is.)
Old Feb 18, 2011 | 10:26 AM
Civic_4life's Avatar
114.3 is 114 some ppl just dont put .3 on the back, civic and regular integra have 4x100, accord/prelude/usdm 4 lug type r are 4x114.3
i say there i way more wheel choice for 4x100 than 4x114.3
Old Feb 18, 2011 | 10:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
114.3mm is exactly 4.5 inches. 4x4.5" is a common lug pattern among both import and domestic compact vehicles.
Honda Accords from the 1990's had a 4x114.3 lug pattern. Not sure if Accord brake rotors (maybe 96-97 V6 rotors) would work with 96-spec JDM ITR suspension or not, even though it is the same lug pattern.
OP what car and suspension setup do you have?
Old Feb 18, 2011 | 11:02 AM
Common way to upgrade 96 spec ITR brakes to 11.1" is to use 92-96 Prelude VTEC rotors with 17CL15VN calipers and 25T brackets.
Old Feb 18, 2011 | 11:05 AM
Community Builder
Oops yeah forgot Preludes used 4x114.3 also.
Old Feb 22, 2011 | 07:16 AM
fredfifty's Avatar
susp consists of kports fully asjustable coil overs as far as i know...its pretty slammed. should i get camber kits? i dont see any irregular wear on my tires.
Old Feb 22, 2011 | 07:45 AM
Community Builder
How slammed is pretty slammed? Pics? Usually you don't need camber correction as long as toe is correct. If you just recently got the car I would go have the alignment checked and adjusted to make sure toe is within factory spec.
Old Feb 23, 2011 | 04:44 PM
jaqattack02's Avatar
I just wanted to ask about wheel compatibility, and this seemed like a good thread for it. I recently got a 1994 LS and it came with an older set of 14" Integra wheels. I'd like to move to a 15" wheel to keep tire prices down. I found a guy willing to trade my wheels for his 2003 Civic wheels. I just wanted to make sure they will fit ok before I trade him. From what I've read it looks like the 03 Civic still had the 4x100 lug pattern. Any differences in offset or anything I should look out for?
The wheels he's trading look like this
[IMG]
http://www.wheelcollision.com/wccpix/63846.jpg[/IMG]
These are what I have:
Seem like a fair trade to you guys? I don't have some kind of rare wheel or anything, do I?
MykHonda
Apr 24, 2014 04:40 PM
Josiah Miller
Apr 25, 2012 09:35 PM
g2tegsownsgirl
May 3, 2006 06:40 AM
SadKorean34
Jan 17, 2006 07:58 PM
EJ8 Kenobi
Feb 3, 2003 11:11 AM
