difference in ECUs
Old Dec 16, 2003 | 02:27 PM
Kidd_Stylez's Avatar
Default difference in ECUs
how do you tell the difference between a USDM and a JDM, OBD1, GSR, ECU just by looking at it? does anyone know??
Old Dec 16, 2003 | 03:37 PM
B16OnTop's Avatar
Default Re: difference in ECUs (Kidd_Stylez)
you look at the numbers on the side, the bar code looking thing, i beleive the jdm OBD1 gsr ecu is P72, but i may be wrong
Old Dec 16, 2003 | 03:45 PM
voltageGSR's Avatar
Default Re: difference in ECUs (B16OnTop)
check out the hondata website..
tells you details.
also; P72 = GSR; both OBD I and II
also beware of OBD 2.1 vs. 2.2 (newer GSR < yr 2000)
peace.
Old Dec 17, 2003 | 12:13 PM
i know its a P72 and it is an OBDI, the only thing i do not know is wether or not its JDM or USDM. How can i tell that? Thanks for the info.
Old Dec 17, 2003 | 12:14 PM
i found it on hondata's website
Old Dec 17, 2003 | 01:44 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kidd_Stylez &raquo;</TD></TR><TR><TD CLASS="quote">i found it on hondata's website</TD></TR></TABLE>
You can tell origin of the ECU by the bar code #'s AFTER the ecu code.
This also tells you which software that particular ecu is using.
HTH
jakl
May 7, 2010 07:19 AM
elnoyl
May 15, 2006 07:42 PM
Kidd_Stylez
Dec 16, 2003 03:38 PM
HYPERION-X
Dec 7, 2003 04:52 PM
wizzards581
Nov 16, 2003 04:20 PM
