DC2 GSR needs help!
Old Aug 24, 2009 | 04:57 AM
JL_DC2's Avatar
Default DC2 GSR needs help!
Ok so i just got my s80 tranny swapped with s80 itr trans. The car idle @ 1500? i check the TB and it's operating like it used to be. anyone know why? i used to drive 60mph on highway and rpm used to be @ 3000 with my gsr trans, now with the new tranny it's @ 3500ish.
And my CEL is on with P0113 code (Intake Air Temp) what should i do, replace that sensor?
Any input or advice would be greatly appreciated!
Old Aug 24, 2009 | 08:15 AM
mouab18c1's Avatar
Default Re: DC2 GSR needs help!
well first a gsr and and itr tranny has different gear ratios, so of course your rpm will be higher than the gsr. and for your IAT either check your wires or just replace the sensor
Old Aug 24, 2009 | 02:36 PM
VtecCustums's Avatar
rpm diff is because the tranny swap, disconnect battery then reconnect unplug IAT run with out shut off plug back in see if you run a code both ways if problem persist get new sensor
Old Aug 27, 2009 | 06:26 AM
JL_DC2's Avatar
what should i do in order to get the rpm back down to normal? reset ecu? idk these stuffs so more info of how to sovle it would really appreciated. thanks everyone for your help
Old Aug 27, 2009 | 10:37 AM
ek-g6's Avatar
You could just make adjustment to your idle screw. Change out your iat sensor, take a trip to the junkyard, and call it a day.
Old Aug 28, 2009 | 04:53 PM
JL_DC2's Avatar
idle screw is all the way min, can't do anything with it. I just replaced new iat sensor and the CEL still on, so i dont think it's the sensor problem.
anyone else experience this?
LuMop
Aug 10, 2006 04:51 PM
burgerbuddy
10
Apr 7, 2005 08:29 PM
Tweakmeister
Nov 25, 2003 09:53 AM
SiR HatchAlot
11
Oct 6, 2003 05:54 PM
SiR HatchAlot
Oct 4, 2003 06:03 AM
