Daytime running lights???
Old Nov 25, 2002 | 05:57 PM
smkngsr's Avatar
Default Daytime running lights???
How can i make my car like that?...i think those are only available in Canada...this looks like those BMW's. when they start, the highbeams are on but kinda look like a teardrop..like an angel eyes...thanks
Old Nov 25, 2002 | 08:24 PM
superfuji57's Avatar
Default Re: Daytime running lights??? (smkngsr)
I got this catalog from SEMA from Autoloc and they have some kinda kit for that.
Old Nov 25, 2002 | 08:50 PM
majeed11's Avatar
So you guys in the US dont have daytime running lights?! didn't know that....
here's how mine look like....
dont know what you mean about it looking like a "tear drop"??
Old Nov 25, 2002 | 09:03 PM
EndlessGarageEG6's Avatar
What you can do is drill holes in your headlight assembly and insert small wedge bulbs into the housing which will give that glowing effect that you want.
Old Nov 25, 2002 | 09:34 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Daytime running lights??? (CRintegreX)
that wouldn't be functional in the daytime. 5W wedge bulbs in the high beam housing would barely be visible.
Old Nov 25, 2002 | 09:41 PM
StinkyTofu's Avatar
Default Re: Daytime running lights??? (majeed11)
majeed11: Just wanted to say that your teg is absolutely gorgeous!
Old Nov 26, 2002 | 02:11 AM
majeed11's Avatar
Default Re: Daytime running lights??? (StinkyTofu)
, thanks
I personally dont like the Day time Running lights... I think it would look better if the corner amber lights were always on instead. .... actually, this reminds me of another question. Is it possible to have the corner/ambers on at full brightness all the time? You know how you signal, it blinks and the blink is brigher than normal. I want that brightness on all the time.
And when signaling, it would blink "on, off, on off", as opposed to "bright, not-bright, bright, not-bright". Does that make sense?
[Modified by majeed11, 11:12 AM 11/26/2002]
Old Nov 26, 2002 | 06:37 AM
IntEGNYC's Avatar
Fierce looking ride dude...
Old Nov 26, 2002 | 07:08 PM
PnX-R's Avatar
That looks really nice.. Now if it were black.. J/K..
So about the DRL's.. What happens when you turn on your Low Beams?? Do the DRL's stay lit??
Because according to the wiring diagram, it seems as if it does stay lit.. And it also seems like by turning on the High Beams, it cancels out the DRL's..
So to do something like that on our cars, it seems as if all we have to do is throw in a Relay and have it send full power to a Resistor block/pack and then jump it to the High Beams.. If it were only that easy..
I think I'll have to try that one of these days..
Old Nov 26, 2002 | 07:36 PM
Ronin Integra8's Avatar
You car looks sweet. How come we dont have integras taht do that here in the US? How do we do it?
Old Nov 26, 2002 | 08:32 PM
Default Re: Daytime running lights??? (PatrickGSR94)
He wanted the "glowing effect" not the functionability. If your looking for the the function then wire up the high beem to work when your lights are off.
when they start, the highbeams are on but kinda look like a teardrop..like an angel eyes...thanks.
Old Nov 26, 2002 | 08:51 PM
Understeer's Avatar
Default Re: Daytime running lights??? (PnX-R)
DRL's are the low beams, which just use less current and are not full brightness, more of a yellow/orange color. When you turn on the low beams on full, the turn signal, low beam bulbs come on full and your dash lights up.
Old Nov 26, 2002 | 09:44 PM
Hexxboy's Avatar
New User
Default Re: Daytime running lights??? (Understeer)
No, actually the DRL's are the highbeams at a reduced power (see the pic in the thread).
First notch on your light switch enables your parking lights. DRL's remain on. High beam indicator is lightly lit (reminds ppl that their headlights are not on, but instead DRL's are being used.. a common mistake)
2nd notch on your light switch turns on your low beams, DRL's turn off. High beam indicator off until actually used.
Old Nov 26, 2002 | 09:53 PM
Understeer's Avatar
Default Re: Daytime running lights??? (Hexxboy)
Oops my bad, I've got it all mixed up.
Old Dec 3, 2002 | 11:01 AM
IntEGNYC's Avatar
I want that now :D
eejayone
Lighting
Aug 19, 2010 07:59 PM
sivik2nr
27
Nov 12, 2003 05:04 AM
95si
Dec 3, 2002 10:11 AM
wizzards581
Jan 11, 2002 12:19 AM
FrostyDC4
Apr 18, 2001 03:50 PM
