dash pot?
Old Aug 25, 2004 | 10:00 PM
93_hatch's Avatar
Default dash pot?
waht is a dash pot? all i know its an emission device for CO, and that it cause the throttle plate not to snap shut but close slowly any one have a promblem with it?
Old Aug 25, 2004 | 10:49 PM
peacexisxfree's Avatar
Default Re: dash pot? (93_hatch)
no, remove the damn thing...
Old Aug 26, 2004 | 05:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
my throttle plate doesn't close slowly, it will snap shut if you let off the gas real quick, as far as I know.
Old Aug 26, 2004 | 06:16 AM
JimBlake's Avatar
Default Re: dash pot? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">my throttle plate doesn't close slowly, it will snap shut if you let off the gas real quick, as far as I know.</TD></TR></TABLE>Dashpots were more common on throttles during '70s to '80s. They were needed because carburators & early injection systems couldn't handle the throttle snapping quickly shut. They'd go obscenely rich for a moment, & EPA didn't like that.
Old Aug 26, 2004 | 07:50 AM
zad5's Avatar
i have on on my carbed crx its only on the carbd cars rite.
Old Aug 26, 2004 | 11:42 AM
93_hatch's Avatar
Default Re: (zad5)
yea i know was looking up info on it later last nite and it was all old cars but y on a 90 teg...
does anyone know if it could cause the RPMs to jump up when stoping like to 1500?
and also at start its at 2000 to 2500 RPMs?
i am goin to to clean the IAC and see if that helps
Old Aug 26, 2004 | 12:33 PM
Default Re: (93_hatch)
i dont think your dashpot would cause any rpm jumps. car throwing any codes? possibly tps or a vacuum leak? the dashpot really isnt necessary on efi cars, especially your 90 teg. if you remove it i guarantee you wont notice a difference
Old Aug 26, 2004 | 01:16 PM
RayB's Avatar
I removed mine on my 90LS back when I had the stock intake manifold and throttlebody. Never really noticed much of a difference.
Old Aug 26, 2004 | 01:27 PM
93_hatch's Avatar
Default Re: (RayB)
the only code is an egr code, which the egr was totally removed and vacuum lines are ghetto rigded maybe a vacuum line
Old Aug 26, 2004 | 02:27 PM
yeah, definitely check the line that used to go to the egr, make sure its plugged nicely. then, check all other vacuum lines
Syndacate
Nov 4, 2009 07:34 PM
IsweatHONDA
Jul 14, 2006 12:06 PM
rolledthatho
Sep 15, 2005 01:02 PM
nc_mx_kid
Dec 28, 2004 06:08 PM
93H22ACX
Jan 17, 2003 09:50 AM
