DA9 B18A1 overheating issue
Old Nov 15, 2014 | 11:12 PM
eman96's Avatar
Default DA9 B18A1 overheating issue
So my 93 Integra RS has been heating up lately. Now, my radiator fan doesn't function properly which I believe helps it overheat but I think there's more to it. Sometimes when it's overheating and I'm at a stop I put it in neutral and start revving it and holding it at around 2k. A lot of the times when I do this the temperature goes down which I find is strange. Any help is welcome.
Old Nov 16, 2014 | 09:23 AM
fcm's Avatar
fcm
Old Fart
Default Re: DA9 B18A1 overheating issue
You need a new water pump and you need to fix the rad fan problem.
The rad fan is needed for when the car is not moving, [no airflow].
Upping the RPM will "move/pump" more coolant by a bad water pump. 94
Old Nov 27, 2014 | 06:58 PM
eman96's Avatar
I see. Is there a way to confirm this, definitely not a cheap replacement.
Old Nov 27, 2014 | 07:08 PM
eman96's Avatar
Also, I never have my A/C on because when the A/C is on it REALLY overheats.
88 EF Hatch
Jul 5, 2009 06:26 AM
chuisek9
May 9, 2008 06:08 AM
DANINEJDM
Jun 2, 2007 08:07 PM
brewerdude
Jan 8, 2006 06:31 PM
KeithGSR
Nov 19, 2004 02:45 PM
