DA owners please help!
Old Jun 11, 2007 | 10:59 AM
NIGHT-DEMON's Avatar
Default DA owners please help!
Hi well i am writing again for somebody that has a da and has a b16 motor swap in it i am swapping a b16a that will be obd 0 into my 91 da that is obd 0 as well does anybody has a list of things i need or the things that i need to do some instructions maybe? thank you!
Old Jun 11, 2007 | 11:02 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: DA owners please help! (NIGHT-DEMON)
Unplug all wires from your motor, labeling what they go to, so it will make it easier for you. Unbolt everything from the car and take off the shift linkage, axles, exhaust and anything else holding the motor in, drop the new motor in, bolt everything up just like how you unbolted it and plug everything back in. Next run a couple wires from your vtec solinoid to your ecu, after that, your set to go.
Old Jun 11, 2007 | 11:05 AM
Default Re: DA owners please help! (St Jimmy)
so basically is all the same and u just have to wire up the vtec solenoid to the ecu?
Old Jun 11, 2007 | 11:17 AM
are the axles the same? motor mounts? shift linkage? ac? power steering pump? alternator?
Old Jun 11, 2007 | 11:27 AM
St Jimmy's Avatar
* B A N N E D *
Yup everything is the same. The only time you would switch parts out is if you were going to go obd1.
Old Jun 11, 2007 | 01:53 PM
Sam92Teg's Avatar
Does he have to worry about a knock sensor?
Old Jun 11, 2007 | 02:04 PM
Rikter's Avatar
Dont' forget to swap ecus as well.. and then when you complain your vtec isint' working do a search before you post another thread.
-Rik
Old Jun 11, 2007 | 02:09 PM
wearedaughters's Avatar
Default Re: (Rikter)
You'll need to wire up a second o2 sensor if you are staying OBD0. Rywire sells a kit that eliminates all the hassle of wiring. It includes the wires to hook up the extra o2 sensor, oil pressure switch, knock sensor, and vtec solenoid. I hacked up the $55 for it and it was more than worth it.
http://rywire.com/store/9091-i...d4eca
barzano724
Nov 12, 2013 08:50 AM
onefastx
Northeast (Sales)
13
Feb 9, 2006 09:27 AM
noboostedEGo
Oct 20, 2005 12:39 PM
90civSi
Jul 14, 2005 10:35 AM
4ghatch
Dec 25, 2002 06:42 PM
