da help
Old Mar 29, 2010 | 02:20 PM
cmyrex's Avatar
Default da help
all right gonna pull my hair out and i hate to ask for help i just recently swaped my 91gs integra wit an 99si b16 rewired car to obd1 using an stock p28 and an obd2 distributor car is not starting checked pins outs for dist fine and pins at ecu all checked fine but seem to be throwing a code 4 and a code 20 i am so lost and stumped only way car starts is when spraying starter fluid in the throttle body if you have come across this problem or know how to fix would be much appreshiated thanks
Old Mar 29, 2010 | 02:37 PM
DumaDA's Avatar
Default Re: da help
looking up the code 4 and 20 for obd 1 seems like they're both from loose wiring, check the wiring to your dizzy. Arent you supposed to use a obd1 dizzy with an obd1 ecu..?
Old Mar 29, 2010 | 02:45 PM
cmyrex's Avatar
Default Re: da help
not if repinned i think
Old Mar 29, 2010 | 02:53 PM
Dee-Aye-9's Avatar
TRIAL USER
Default Re: da help
I had a very similar issue with my da, Check to see if the injectors are actually getting signal from the pcm. if your fuel pump is priming and the pressure is good and the compression is good and it is obviously getting air make sure the pcm is doing its job
Old Mar 29, 2010 | 02:56 PM
Dee-Aye-9's Avatar
TRIAL USER
Default Re: da help
if the injectors are not getting signal its ether the tdc(cam) sensor inside the distributor or the pcm is fried
Old Mar 30, 2010 | 05:27 AM
Dee-Aye-9's Avatar
TRIAL USER
Default Re: da help
oh a 91 would be obd0 but i dont think that will change the meaning of the codes
Old Mar 30, 2010 | 06:40 AM
freakin_eLRoD's Avatar
Default Re: da help
it shouldn't change very much if at all, and op said he is running an obd1 ecu and that he converted over from obd0 to obd1
Old Mar 30, 2010 | 07:14 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: da help
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
slow_low_eddie
Mar 2, 2014 12:06 AM
EG6_LS_BOOST
15
Jul 17, 2013 02:55 PM
Wilka
Nov 14, 2012 01:36 AM
hatch_kidb18b1
May 11, 2010 03:05 PM
