DA climate control issues
Old Oct 14, 2011 | 10:07 PM
ryguy2588's Avatar
Default DA climate control issues
Hey guys,
I just picked up a DA integra about a week ago and when the hot or cold air is on, the air only comes out the dash vents. No matter what button I press, it doesn't change. It won't go to the defroster at all. What could be the issue? Sounds an electrical problem, but I don't know much about the heating and cooling system to start tearing it apart. Any help is much appreciated.
Old Oct 15, 2011 | 12:52 PM
ryguy2588's Avatar
Default Re: DA climate control issues
ttt
Old Oct 15, 2011 | 05:08 PM
fcm's Avatar
fcm
Old Fart
What year is your DA?
Sounds like either the Mode Control Motor is NG, linkage is disconnected/broken, or wiring to the MCM is bad, maybe even the control head. [HVAC Controls].
You can look up under the drivers side of the dash to the side of the heater box to see the heater unit, [#2] the Mode Control Motor, [#5] and Mode levers, [#s 6 8 9 11 14 and all the little parts that go with them...
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
First thing to look for, is the motor plugged in?
Second, check the "levers", make sure nothing has come apart or is broken.
You can turn on the ign. and see if there is any movment as you switch the modes, it will be hard to see if the motor works, [turning on a broken shaft], remove the motor, you can then see the "drive shaft" move, if the motor works.
With the motor out you can move the levers by hand to see if all the doors/flaps are working, if they are it is a good bet the motor was/is not working, then you need to find out why, simple way is to plug in a known working one, other wise you will need to break out the multimeter an do some testing, 94
Old Oct 15, 2011 | 06:05 PM
ryguy2588's Avatar
Ok great. I'll do some playing around and let you know how it goes. Thanks so much.
Old Oct 15, 2011 | 11:23 PM
1fastvtec's Avatar
Mine did that and it was the fuse.....
Old Oct 16, 2011 | 07:21 AM
fcm's Avatar
fcm
Old Fart
Ditto that^^^. ryguy2588 you did check the fuses, right? 94
Mkb897
Apr 17, 2012 07:27 PM
DC206R
May 6, 2009 04:00 PM
D16Z6_turbo
Oct 5, 2007 11:05 PM
user 528629372
Oct 18, 2005 08:07 AM
VeilSide_Mas
Jul 20, 2005 01:18 PM
