Custom Intake (How To)
i wanted to know if it would look good if i cut out the inside light (High Beam) on the passanger side of my car and made a custom pipe that was my intake go through the hole, barely.......how would i go about cutting the light and how would i seal it to prevent condensation in the headlight.......?
I’m going to do the something for my turbo. The way i was thinking of doing it is to drill 2-3mm holes all over the high beam light. Take the bulb out drill a couple of holes around the bulb. Then run some ducting to my filter. I want to make it look for the most part stock just by glancing at the car. I think it would cause condensation in the other side.
-Aaron
-Aaron
I dont think u should do it...its not like u'll be going fast enough for it to push more air into the intake..wheel well location is just as good..my opinion though
i say for turbo or NA guys with a sri.. just get some 2"/3" flexy dryer hose and put it down by one of your lower vent cut outs on the passanger side of the bumper. and aim it right at the filter.. brings in cold air from the "ram" effect and you could also put small little 1/4 holes in the tube to prevent any wanter from slowly crawling up the pipe while driving
MikeTV
Dec 25, 2004 08:35 AM
animated_life
Dec 27, 2003 12:03 PM
