Engine making clicking noises
Old May 12, 2004 | 03:36 PM
mal42985's Avatar
Default Engine making clicking noises
I have a 1995 Acura Integra LS and I came back from school today and when I went to start my car I noticed a weird clicking noise and immediately shut it off. So I popped the hood and has someone turn the engine over for me. It sounds stupid but it sounded like there was something in the engine bouncing around. I know that isn't the case it just sounded like that. Now I know I need to look at my timing belt to see if it needs to be replaced and I was wondering if it could have anything todo with that. Also I need to change the oil. But if the timing belt snapped it would not be able to run and I would be screwed. Right? Well if anybody has any idea just let me know. Also there is no check engine lights. Thanks.
Old May 12, 2004 | 04:10 PM
t . b o z's Avatar
Default Re: Engine making clicking noises (mal42985)
If the timing belt snaps...you fucked. If it looks worn, replace it. Or if your motor has 100k+ on it, I would suggest replacing asap. But to address that clicking noise...you may just need a Valve Adjustment. If I were to pick a worst case scenario, it would be that you bent a valve. Have you over-revved it excessivley in the past? e.g. missed shifts, being a stunna, taking it way past redline, etc.. etc...
Old May 12, 2004 | 04:15 PM
v63000gtv6's Avatar
Default Re: Engine making clicking noises (TimmydaTeg)
Well the thing is that I am trying to sell the car. I was just going to sell it for less and let them replace it. And yes the engine is over 100k+. My car is an automatic so it doesn't really go over redline and also I haven't revved it up at all recently. It actually happened when someone took the car out for a test drive while I was at school. It was pooring rain and I don't have the tire lining inside the tire hub and water got into the cold air intake. I don't know if this had anything todo with it.
Old May 12, 2004 | 04:16 PM
mal42985's Avatar
Default Re: Engine making clicking noises (v63000gtv6)
That post above was me. Sorry for doing it in another name.
Old May 12, 2004 | 04:25 PM
boostinb20vtec's Avatar
if water got sucked up the intake, then you more than likely have fucked up timing and some bent valves.
Old May 13, 2004 | 07:20 PM
mal42985's Avatar
Default Re: (boostinb20vtec)
Ok I finally compression tested it and here are the results. I did not start the car and let it run for 15 minutes because it runs horribly and if there is a major problem I don't want to mess up the cylinder walls or something to that affect. But I did two test an hour apart with multiple trials on each one. Here are the results.
<U>Cylinder</U>
#1 #2 #3 #4
Test 1 120 160 150 180
Test 2 120 150 150 170
Obviously there is something wrong with the #1 so tomorrow I am going to change the oil to see if there is any anti freeze in it. I mean I know that it could be bent valves but could it be anything else other than the headgasket? My guess is that I sucked in water and bent some valves in cylinder #1. Also is there a big enough gap between the other ones to worry about them?
Old May 14, 2004 | 06:09 AM
mal42985's Avatar
Default Re: (mal42985)
Bump
Old May 14, 2004 | 08:24 AM
greaseball's Avatar
#3 doesn't look so hot either. looks like it's time for new valves . good luck man.
Old May 14, 2004 | 09:20 AM
xplanetearth420x's Avatar
Default Re: (greaseball)
im thinking you have bent valves
grinder_1
Classic Hondas
Sep 18, 2018 03:08 AM
CivicSos
20
Apr 21, 2014 06:00 AM
kemo909
Apr 29, 2010 07:51 PM
WillyD6869
Jun 13, 2005 11:46 AM
