CRVTEC
Old Apr 30, 2002 | 09:17 AM
kevinm1981's Avatar
Default CRVTEC
I need some info on the crvtec in a integra. I'm thinking about doing it, how much would it cost to do the swap? Eventually I'll rebuild the bottom end and turbo it.
[Modified by kevinm1981, 6:39 PM 4/30/2002]
Old Apr 30, 2002 | 09:20 AM
GokuSSJ4's Avatar
Default Re: CRVTEC (kevinm1981)
how you seen your options on going with LS/VTEC or even going Turbo ??
Old Apr 30, 2002 | 09:39 AM
kevinm1981's Avatar
Default Re: CRVTEC (Spoon1)
what?
Old Apr 30, 2002 | 10:20 AM
kevinm1981's Avatar
How much does it cost to put together a crvtec?
Old Apr 30, 2002 | 10:51 AM
Tomakit's Avatar
a lot.
Tom
Old Apr 30, 2002 | 11:19 AM
kevinm1981's Avatar
Default Re: CRVTEC (Tomakit)
More then buying a itr motor? wtf?
Old Apr 30, 2002 | 11:36 AM
threatcon13's Avatar
New User
not more than an ITR motor. go to http://www.crvtec.com for more info.
Old Apr 30, 2002 | 01:20 PM
dynamite C1's Avatar
for $4,700 this is what we got...
B16 head (first gen B16)
B20 B (CRV engine 2.0 lt)
JE pistons (11 to 1 comp)
Eagle light weight rods
Balance/Blue print
New oil seal
GSR transmition (ideal trans for the CRVtec setup)
Reprogramed ECU (6000 rpm activation and 9000 rpm redline)
Portflow inner valve springs and taitainium retainers
6 puck spring clutch
custom engine mounts from place racing.
So with your stock B18c all you need is the B20 Block ($600-$800)
Plus install
with stock pistons but trim the intake valve, reuse stock head, intake manifold, tranny, header, ECU, 180whp with 155lbs of torque @ 3,000rpm.
SpeedOFsmell
10
Dec 23, 2014 09:52 AM
Rpicano
Apr 10, 2013 06:59 AM
white_n_slow
18
Aug 18, 2004 11:47 AM
Irishweird00
52
Jun 3, 2003 01:06 PM
