crap... Compression results...
Old Sep 10, 2004 | 05:59 AM
s2kkid's Avatar
Default crap... Compression results...
So i get my gsr, and i do compression tests on it after i pushed down to 4th, and it went into 2nd(my bad)
cyl 1 200
cyl 2 50
cyl 3 0
cyl 4 50
after i put oil in the cylinder, i got:
cyl 1 225
cyl 2 100
cyl 3 10
cyl 4 80
the odometer shows 197k. I think this thing is shot. needs rebuilding. Im considering getting a low mileage swap package since i have a bad 2nd synchro, and for the price i could just swap it all out.
Where can i get a package for a good price... Im not concerned in some 4000 buck ITR motor. I want a good gsr motor that will be decent to turbo.
how much would it cost me to have the engine rebuilt(machiene work done by a shop) and me put the pistons, crank, rods, and send the head off to get reworked?
Engine removal and installation wont be an issue, as ill do it all myself..
Tips very welcome here.
Old Sep 10, 2004 | 05:48 PM
patmcd's Avatar
Default Re: crap... Compression results... (vtecluder97)
Are you sure you did the test right? Those are some really bad numbers.
Old Sep 10, 2004 | 08:40 PM
integraL's Avatar
Default Re: crap... Compression results... (patmcd)
yeah too BAD to be true!
Old Sep 10, 2004 | 08:57 PM
ntegls's Avatar
Do a leak down, you might have bent some valves.
Old Sep 11, 2004 | 12:37 AM
s2kkid's Avatar
Honestly I dont know how good the integrity of the test is.
I borrowed a snap on compression tester from a guy at work.
its the 2 piece setup where you thread one end down into the sparkplug hole, and connect it at the top with a air compressor like fitting.
problem is, I did the test over and over, thinking i didnt do it right. I would take it out, thread it right back in hopeing something wasnt right.
Kept getting the same numbers. I poored oil in the spark plug holes, and sure enough the numbers changed across the board as i did this.
WTF is wrong here...
how much would it cost me to do a moderate rebuild to get the motor more reliable for turbo. Im leaning towards putting a used low mileage swap in for like 2grand or whatnot.
I feel that if i rebuilt the motor it would cost me more even if i did a good bit of the work.
Suggestions?, Places to call? could use some of this info
Old Sep 11, 2004 | 01:06 AM
jaydeemmmm's Avatar
You might have the same problem as me. Valve tap. You can hear pinging noises on low RPM or on hills. I hope it's nothing too serious.
Old Sep 11, 2004 | 01:34 AM
94teg_RS's Avatar
if your going turbo why not get a ls motor
Old Sep 11, 2004 | 04:14 AM
s2kkid's Avatar
nah man, i would really like to go back with the gsr motor, im pretty pleased with it but i need to know where i can get this fixed for under 2k with me pulling the motor, disassembleing it, and reassembleing it if needbe.
Old Sep 11, 2004 | 05:55 AM
Ri5e's Avatar
Default Re: (vtecluder97)
For all that rebuilding money, you could easily have a 300 WHP LS monster ...
Old Sep 11, 2004 | 10:48 AM
cjohnson_2's Avatar
Default Re: (BG Boost)
TAke off the head. Your gonna have to anyways.
Old Sep 11, 2004 | 12:31 PM
neo1z's Avatar
Default Re: (cjohnson_2)
Not unrealistic. Ive seen a 150 75 0 25 in person. Wack
Old Sep 11, 2004 | 05:34 PM
s2kkid's Avatar
Default Re: (neo1z)
well i mean what am i doing wrong here... I desided to come back out this morning and do it, and i got the same results.
You dont think this tester i borrowed, is a Pos do you?
Old Sep 12, 2004 | 07:55 AM
neo1z's Avatar
Not especially - if you know what you're doing, you probably just blew the motor.
slammedbbs
May 9, 2011 04:14 AM
rotascircuit
Jan 16, 2010 10:16 AM
zc89hatch
13
Dec 21, 2008 11:40 AM
GsrIntegra789
Oct 9, 2006 12:14 PM
