CPS (Crank position sensor) code?
Old Oct 30, 2007 | 04:58 PM
96GS-R-Kaden's Avatar
Default CPS (Crank position sensor) code?
CPS (Crank position sensor) code is showing up on my 96 GS-R, what is that and exactly were is it located? Car wont rev past 3500k....
Please help!!!
Old Oct 30, 2007 | 06:14 PM
berb_15's Avatar
Default Re: CPS (Crank position sensor) code? (96GS-R-Kaden)
can't tell you exaaaactly what it does but it mounts onto your oil pump right at the crank kind of in between the crank pulley and pump
Old Oct 30, 2007 | 06:18 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
The crankshaft position sensor is designed to record the rate at which the crankshaft is spinning. This sensor consists of a toothed metal disk mounted on the crankshaft and a stationary detector that covers a magnetic coil that the current passes through. As the metal teeth move past the coil, its magnetic field is disturbed. This causes a stream of pulses in the current. The computer can calculate the crankshaft's speed from the frequency of the pulses.
Default Re: CPS (DOHCgarage919)
With no signal from the crank position sensor the ignition module won't generate a spark.
Old Oct 31, 2007 | 05:42 AM
Could this be why I can't rev passed 3500K? How do I replace it?
Old Oct 31, 2007 | 04:17 PM
Default Re: (96GS-R-Kaden)
get a new sensor
Old Oct 31, 2007 | 04:19 PM
all-mtr-teg's Avatar
Default Re: (DOHCgarage919)
would that cause a misfire code cylinder 1 and 3?
Old Nov 8, 2007 | 11:24 AM
howfastcanigo's Avatar
Im also having a problem with my car running right. The timing was off a little. then i broke one of the teeth on the crank gear which caused the car to not even start. if your going to replace the crank sensor you might also think about replacing the time belt, water pump, etc. depending on your mileage and belt condition. I will warn you that if you leave your alternater diconected from the motor it will send a ground spike to your pcm and fry it. the Pcm is over four hundred dollars. I might be in this situation after talking to a honda tech.
Old Apr 11, 2008 | 07:03 AM
JUNKIE DUCKY's Avatar
Default Re: CPS (howfastcanigo)
so wat does it plug into wat part of the harness? I dont remember nothing plugging up by crank pulley how does it work ?
Old May 30, 2008 | 09:46 AM
pinks11's Avatar
Default Re: CPS (JUNKIE DUCKY)
I'm going trough this problem too. For the past couple weeks, ever since I swapped in a 91 si flywheel, pressure plate, and a cluch along with a cable hf tranny to a d16y7 its been acting up. The car would have a hard time starting when its cold. But more recently a week ago, I swapped in an si tranny and for the past couple days the car would just turn off right after I punch it. There seems to always be a misfire, and the engine bogs out when I floor it completely. Will the flywheel make a difference on the rotation/timing of the crank and crank sensor?? The 91 flywheel is slightly bigger than the flywheel that was on the motor when I took it off, so maybe that might be the cause?? If someone knows a lot about this reply or send me a pm, your time will be much appreciated
Old May 30, 2008 | 05:02 PM
lmike6453's Avatar
you guys need to slow down, read my thread, and ask me any questions you have...
https://honda-tech.com/zerothread?id=2291562
civic1999si
Nov 2, 2019 06:25 PM
Keno Smith
Nov 5, 2012 10:56 AM
rbizzell30
Jul 10, 2008 09:41 PM
90h22acrx
Oct 8, 2004 07:58 PM
