Cooling problem
Old May 15, 2005 | 08:23 PM
justinb's Avatar
Default Cooling problem
I have a 91 Integra and It heats up way to hot. While it is doing this I turn the heat on it is cold. No heat in my vents while it is over heating. Mostly happens when I am in stop and go traffic. Just changed the thermostat, water pump, and radiator. What else can cause this? PS No fluid leaks in my system
Old May 15, 2005 | 08:44 PM
DAguyLS's Avatar
all i can think of is you might of gotten a shitty thermostat. it happens. i know people who've had bad luck with 2 or 3 before they got a properly working thermo. GL with this issue
Old May 15, 2005 | 08:53 PM
justinb's Avatar
Is there anything in your cooling system that controls it other then thermostat, water pump,and radiator/ fan?
Old May 15, 2005 | 11:39 PM
ALMXDUPINTEGRA's Avatar
Sounds like thermostat issue have it checked
EJ1_CRIS_909
Jul 18, 2012 10:03 PM
chuisek9
May 9, 2008 06:08 AM
89_ZC_crx
Mar 12, 2006 08:35 AM
J1A1H
18
Jan 8, 2006 12:13 PM
CptCorN
28
Feb 6, 2005 06:23 PM
