confused!!!!
Old Jan 20, 2006 | 05:22 PM
grg9988's Avatar
Default confused!!!!
are b series intake manifolds inter changeable, will a b18a intake manifold of a 90 obd0 teggy fit a jdm b18b in order to convert to obd0???
any help would be great , by the way the motor is going into a 91 civic hatch dx
Old Jan 20, 2006 | 06:43 PM
teg racer 877's Avatar
Default Re: confused!!!! (grg9988)
yea I think u will be fine with that.
Old Jan 20, 2006 | 09:19 PM
CaseBone's Avatar
Yes i believe all b-series intake manifolds are interchangeable except for the B18C1
Old Jan 21, 2006 | 03:40 AM
Geno's Avatar
Default Re: confused!!!! (X92B18C1TegX)
Um, from what I remember, only the b16 and b18c5 have interchangable intake manifolds, the GSR mani and ls mani are different.
Old Jan 21, 2006 | 04:55 AM
gsrboi80's Avatar
Default Re: confused!!!! (Geno)
They will all bolt up GSR mani has the secondary runners
Old Jan 21, 2006 | 10:22 AM
shorto85's Avatar
LS intake manifolds will only fit LS/B20 heads. GSR IM will only fit GSR heads. B16/ITR manifolds will interchange.
EDIT: OK thought I would add some pictures to help people out...
B18B IM
I don't have any GSR IM pictures.... sorry
Modified by shorto85 at 11:33 AM 1/21/2006
Old Jan 21, 2006 | 10:25 AM
dohcMONSTER's Avatar
Default Re: (shorto85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 &raquo;</TD></TR><TR><TD CLASS="quote">LS intake manifolds will only fit LS/B20 heads. GSR IM will only fit GSR heads. B16/ITR manifolds will interchange.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrboi80 &raquo;</TD></TR><TR><TD CLASS="quote">They will all bolt up GSR mani has the secondary runners</TD></TR></TABLE>
Old Jan 21, 2006 | 10:29 AM
blakezilla06's Avatar
Does anyone have a clue as to what they are saying? Everyone has a different story...
From what I understand and remember though this is correct!
Old Jan 21, 2006 | 10:32 AM
<U>
this is correct
</U>
Old Jan 21, 2006 | 10:35 AM
shorto85's Avatar
Posted a couple of pictures comparing the ITR and LS manifolds... if someone could post a picture of the bolt patter to the B16 and GSR manifolds that would be great.
I hope people read through this whole thread and are able to find the truth...
Old Jan 22, 2006 | 05:20 PM
Geno's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 &raquo;</TD></TR><TR><TD CLASS="quote">Posted a couple of pictures comparing the ITR and LS manifolds... if someone could post a picture of the bolt patter to the B16 and GSR manifolds that would be great.
I hope people read through this whole thread and are able to find the truth...</TD></TR></TABLE>
ITR and B16 are the same.
Old Jan 23, 2006 | 06:37 PM
grg9988's Avatar
so the only interchangeable manifolds are the b16 and the r right, and all the ls manifolds are all the same ,runners wise right, or are they different depending on the year
and what i meant by the motor is going into a 91 dx is that i'm trying to convert the b18b into obd0 and drop it into the civic
Old Jan 24, 2006 | 01:45 AM
Geno's Avatar
Default Re: (grg9988)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grg9988 &raquo;</TD></TR><TR><TD CLASS="quote">so the only interchangeable manifolds are the b16 and the r right, and all the ls manifolds are all the same ,runners wise right, or are they different depending on the year
and what i meant by the motor is going into a 91 dx is that i'm trying to convert the b18b into obd0 and drop it into the civic</TD></TR></TABLE>
Runners are the same, throttle bodies are going to be different sensor wise, as well as the locations of the coolant hoses into and out of the throttle body/intake manifold.
Old Jan 24, 2006 | 08:00 PM
grg9988's Avatar
so i should be fine with the obd0 intake mani in the obd1 block right
Old Jan 24, 2006 | 08:56 PM
mr.beeks's Avatar
dont forget about the EGR valve...... for obd0
Old Jan 24, 2006 | 10:44 PM
riceball777's Avatar
there are 3 b seris im bolt patterns
1 b16/itr
2 gsr
3 Ls/b20
twistedimage
Apr 7, 2022 05:44 AM
bigboi_626
Jul 4, 2007 04:26 PM
Nicaraguense13
Sep 12, 2006 05:28 PM
integraballs
Apr 24, 2006 10:38 AM
megotvtec
Mar 7, 2004 01:17 AM
