confused!!!!
are b series intake manifolds inter changeable, will a b18a intake manifold of a 90 obd0 teggy fit a jdm b18b in order to convert to obd0???
any help would be great , by the way the motor is going into a 91 civic hatch dx |
Re: confused!!!! (grg9988)
yea I think u will be fine with that.
Yes i believe all b-series intake manifolds are interchangeable except for the B18C1
Re: confused!!!! (X92B18C1TegX)
Um, from what I remember, only the b16 and b18c5 have interchangable intake manifolds, the GSR mani and ls mani are different.
Re: confused!!!! (Geno)
They will all bolt up GSR mani has the secondary runners
LS intake manifolds will only fit LS/B20 heads. GSR IM will only fit GSR heads. B16/ITR manifolds will interchange.
EDIT: OK thought I would add some pictures to help people out... http://www.theoldone.com/articles/co...Comparison.jpg B18B IM http://www.team-integra.net/images/B...ld_calc/IM.jpg I don't have any GSR IM pictures.... sorry Modified by shorto85 at 11:33 AM 1/21/2006 |
Re: (shorto85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 »</TD></TR><TR><TD CLASS="quote">LS intake manifolds will only fit LS/B20 heads. GSR IM will only fit GSR heads. B16/ITR manifolds will interchange.</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrboi80 »</TD></TR><TR><TD CLASS="quote">They will all bolt up GSR mani has the secondary runners</TD></TR></TABLE> https://honda-tech.com/forums/images...s/emthdown.gif https://honda-tech.com/forums/images...s/emthdown.gif |
Re: (shorto85)
Does anyone have a clue as to what they are saying? Everyone has a different story... <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 »</TD></TR><TR><TD CLASS="quote">LS intake manifolds will only fit LS/B20 heads. GSR IM will only fit GSR heads. B16/ITR manifolds will interchange.</TD></TR></TABLE> From what I understand and remember though this is correct! https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (shorto85)
<U> this is correct</U> |
Posted a couple of pictures comparing the ITR and LS manifolds... if someone could post a picture of the bolt patter to the B16 and GSR manifolds that would be great.
I hope people read through this whole thread and are able to find the truth... |
Re: (shorto85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 »</TD></TR><TR><TD CLASS="quote">Posted a couple of pictures comparing the ITR and LS manifolds... if someone could post a picture of the bolt patter to the B16 and GSR manifolds that would be great.
I hope people read through this whole thread and are able to find the truth...</TD></TR></TABLE> ITR and B16 are the same. |
so the only interchangeable manifolds are the b16 and the r right, and all the ls manifolds are all the same ,runners wise right, or are they different depending on the year
and what i meant by the motor is going into a 91 dx is that i'm trying to convert the b18b into obd0 and drop it into the civic |
Re: (grg9988)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grg9988 »</TD></TR><TR><TD CLASS="quote">so the only interchangeable manifolds are the b16 and the r right, and all the ls manifolds are all the same ,runners wise right, or are they different depending on the year
and what i meant by the motor is going into a 91 dx is that i'm trying to convert the b18b into obd0 and drop it into the civic</TD></TR></TABLE> Runners are the same, throttle bodies are going to be different sensor wise, as well as the locations of the coolant hoses into and out of the throttle body/intake manifold. |
so i should be fine with the obd0 intake mani in the obd1 block right
Re: (grg9988)
dont forget about the EGR valve...... for obd0
there are 3 b seris im bolt patterns
1 b16/itr 2 gsr 3 Ls/b20 |
