Comptech vs Beaks
Old Nov 13, 2001 | 10:39 PM
Halo's Avatar
Default Comptech vs Beaks
Comptech sells a rear lower tie bar reinforcement for sway bars. I don't feel like shelling over $400 to comptec, yet I don't want my rear bar to tear out!!!! Is the Beaks Kit just as good? http://solar.innercite.com/comptech/product316.html
[Modified by Halo, 11:40 PM 11/13/2001]
Old Nov 13, 2001 | 10:49 PM
Halo's Avatar
Default Re: Comptech vs Beaks (Halo)
my car is a 97 Civic hatch hybrid. Those cars don't come with rear swaybars, so it needs to be tough.......I.E-from autox track to home to school to the market etc, etc,..All purpose
Old Nov 14, 2001 | 05:32 AM
Halo's Avatar
anyone??? Bueller? Bueller?
Old Nov 14, 2001 | 05:36 AM
sackdz's Avatar
Good movie.
Old Nov 14, 2001 | 06:04 AM
fastbrakes's Avatar
The Beaks kit works just fine, I've had mine on for over a year with no problems whatsoever.
Old Nov 14, 2001 | 06:19 AM
MattG's Avatar
New User
The comptech is more than a tear out kit. It is a tie bar. It keeps the connection points for the lower control arms from flexing. The build quality of this peice is great. I just got mine the other day. If you are considering a tie bar I would just go ahead and get the comptech kit. It all works out since a comptech tie bar alone is about $200. Plus Comptech sends everything you need to install (all new bolts, bushings, lube, loctite, etc).
Old Nov 14, 2001 | 09:53 AM
BSQ's Avatar
BSQ
I normally would not recommend the Comptech tiebar/swaybar combo (nice product but high price tag), but in your case (since you own a '97 Civic) I would recommend it. The reason that I say this is because the '96-'00 Civics are prone to subframe tearout when using a larger rear swaybar. The reason they have trouble is because the mounting points on the subframe are on the very outside edge of the suframe sheetmetal, which does not provide a rigid enough surface for a larger swaybar to mount to. If you have ever notice the '92-'95 Civic / '94-'01 Integra / '93-'97 Del Sol (they all share the same suspension subframe) swaybar mounting points are on the inside of the subframe (ie. inside of the lower control arm bolt), which provides a much more stable and secure mounting point for the Type-R, as well as other larger, rear swaybar. So the best bet, in your case, would be to purchase the Comptech tiebar/swaybar combo.
BTW, Beaks kit (along with my BSQ Type-R rear swaybar mounting kit) will not work on a '96-'00 Civic since the subframe is different.
Old Nov 14, 2001 | 02:02 PM
Halo's Avatar
Default Re: Comptech vs Beaks (BSQ)
BSQ-What are the chances that the comptech, could tear out also? If anyone has had their swaybar tearout, I know you understand my paranoia. Cost me $1k to fix!!!
Old Nov 14, 2001 | 05:31 PM
Eeepers's Avatar
New User
Get the comptech kit. It won't tear out.
Old Nov 14, 2001 | 06:13 PM
BSQ's Avatar
BSQ
I would not worry about the Comptech tiebar/swaybar combo tearing out. The way that it is attached to the suspension subframe should eliminate all chances of subframe tearout. I do understand your paranoia and I hope that I (and others) have at least put your mind at ease.
Old Nov 14, 2001 | 06:16 PM
Halo's Avatar
thanks man
Old Nov 14, 2001 | 07:11 PM
1fastGSR's Avatar
New User
The Comptech combo is well worth it! I paid $350 amd I love it. It looks awesome from behind the car, nice and shiny!
Old Nov 14, 2001 | 07:37 PM
Halo's Avatar
Default Re: Comptech vs Beaks (1fastGSR)
can you please tell me where you got that price? On comptech website I think it's like $389
irev210
May 5, 2004 08:17 PM
xsnrgsr
Jul 12, 2003 07:58 PM
96 SOHC VTEC
May 9, 2003 09:20 AM
RC211V
Aug 6, 2002 11:24 AM
