compression test...a couple of questions....
Old Dec 9, 2003 | 04:48 PM
RAS Motorsports's Avatar
Default compression test...a couple of questions....
i just did a compression test today (95 GSR)...120.135.130.130....which i REALLY low after searching other peoples number. I also did the wet test and my numbers jumped to 210-220. Which makes me think that my rings are going. But when i searched it said that I should have tested at WOT and should have pulled my fuel pump fuse. O and my engine was VERY cold. Does it really matter if i didn't do these things? Making my numbers THAT low?
Old Dec 9, 2003 | 04:59 PM
SubieDude's Avatar
Default Re: compression test...a couple of questions.... (95GeeZR)
I dont think it should matter that the motor was cold...but you definetly need to replace those rings...maybe time for a rebuild with some nicer internals
Old Dec 9, 2003 | 05:31 PM
Default Re: compression test...a couple of questions.... (WhiteS2)
do you think its only my rings? and would my rings being so worn...wouldn't it make my motor run very rough? my motor still runs strong...no burnt oil...no smoke...makes me wonder if it really is just my rings....
Old Dec 9, 2003 | 05:32 PM
SubieDude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GeeZR &raquo;</TD></TR><TR><TD CLASS="quote">do you think its only my rings? and would my rings being so worn...wouldn't it make my motor run very rough? my motor still runs strong...no burnt oil...no smoke...makes me wonder if it really is just my rings....</TD></TR></TABLE>
well how many miles are on the motor...thats the only thing i could think of..
Old Dec 9, 2003 | 05:46 PM
J337_UNIT's Avatar
Engine should be warmed to normal operating temperature. The pistons rings and valve seals will expand under heat giving the best seal resulting in the best number for compression. Testing should be done with WOT. If not you will get poor results. and yes pull the 15a fuse (F/I ECU) and crank the motor through as many compression cycles as it takes till the needle ont the tester no longer rises
Old Dec 10, 2003 | 04:36 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GeeZR &raquo;</TD></TR><TR><TD CLASS="quote">do you think its only my rings? and would my rings being so worn...wouldn't it make my motor run very rough? my motor still runs strong...no burnt oil...no smoke...makes me wonder if it really is just my rings....</TD></TR></TABLE>Before you go off panicked, just do the compression test again properly. That's pretty easy...
1) Engine should be warmed up completely.
2) Pull a fuse or unplug the injectors - you don't want gasoline.
3) I unplug the distributor so the coil isn't trying to fire. I'm not sure if this is important...
4) Wide-open throttle.
5) Keep cranking until the gauge stops climbing higher. That might be 6 or 8 compression strokes on that cylinder.
Old Dec 10, 2003 | 05:16 AM
Rory Breaker's Avatar
Default Re: compression test...a couple of questions.... (JimBlake)
Exactly...#s will be lower when the car is cold. You need to make sure the motor is @ normal operating temperature, and pull the fi/ecu fuse so no fuel is involved. I wouldnt crank more than 10 times or so...by then, the guage should be peaked.
DulinDragons
Dec 3, 2009 09:05 PM
GdmLaz
Jan 28, 2008 04:54 PM
HighRevn
Jul 26, 2006 08:24 AM
sol_tuner
Feb 23, 2005 03:15 PM
gsr~hatch
Apr 17, 2003 03:19 PM
