compression test
Old Jun 27, 2002 | 05:41 AM
fuguman's Avatar
New User
Default compression test
just did a compression test (95RS 115K)
here are the #'s
200,200,195,210
the manual says it shold be 199 so i'm pretty happy with the first 3 but the last one??? whats up with that
how much carbon build up do i have?
anyway u think i'm safe to go 5-7psi turbo?
is there anything i can do about the last cylinder to lower to 210?
Old Jun 27, 2002 | 07:54 AM
ragejed's Avatar
Default Re: compression test (fuguman)
get some of that crap u put in the gas tank that cleans your engine well...the head part at least , then try the test again
Old Jun 27, 2002 | 11:19 AM
mingchi96
Guest
Posts: n/a
cylinders 2 and 3 will always tend to be lower than 1 and 4 so thats normal. Try doing it again, but with a wot.
Old Jun 27, 2002 | 11:26 AM
98DC2's Avatar
got a 98 gsr. all 4 cylinders read 210. I held pedal for same amount of time for each. however, i did use a bottle of STP complete fuel system treatment, but i don't think that makes a big difference. My suggestion would be for you to get somekind of fuel treatment formula, run synthetic oil & tranny fluid, use 93 octane gas, then run another compression check.
Old Jun 27, 2002 | 11:35 AM
GSRwBOOST's Avatar
Default Re: compression test (98lagen)
boost on!!!!
you want no more than 20psi between the highest and lowest numbers
mine are around 185-190 on a gsr engine with 8.5-1 compression pistons... so that's not that bad... stock mine was like 210roughly
Old Jun 27, 2002 | 11:46 AM
fuguman's Avatar
New User
Default Re: compression test (mingchi96)
i did do it with WOT
what does running higher fuel and synthetic fluids have to do with getting good compression test results???
you thing that i would be able to get rid of some of that build up with fuel system treatment?
Old Jun 27, 2002 | 12:08 PM
98DC2's Avatar
smoother....probably make comp. test results a little more accurate
niterider96cord
Jun 22, 2010 07:46 PM
TheCrimsonGhost666
May 4, 2010 08:27 PM
civic_driver
23
Jun 12, 2009 07:55 AM
wm5holla
Mar 23, 2003 03:39 PM
Andrew 825SM
Oct 19, 2002 10:05 PM
