Compression test?
Old Nov 16, 2001 | 11:39 AM
Audipwr1's Avatar
Default Compression test?
What should the compression be on a 1996 GSR i am lookin at one that has 175 all around is that good??
Old Nov 16, 2001 | 02:58 PM
FSTASNTZ's Avatar
Default Re: Compression test? (Audipwr1)
If it is consistant across all four, 175 like you said, I would see that as a good engine. Remember the compression number may sound low compared to your friend a state away using a Snap On compression checker. Why? Not all the gauges come with the same size nipple to go into the spark plug hole.
Jason
Old Nov 16, 2001 | 08:22 PM
nugget8000's Avatar
New User
Default Re: Compression test? (FSTASNTZ)
Also, for a more thurough diagnostic, I would recommend a leakdown test. It will give you a much more detailed analysis of whats going on inside an engine in terms of how well it's sealing up. I would definitely do a leakdown test before buying a new car.
Old Nov 16, 2001 | 08:42 PM
leechungsr's Avatar
Default Re: Compression test? (nugget8000)
leakdown is not necessary unless the compression numbers are way off in each cylinder (like 10% off). Depending on the calibration of the tester, sounds good. When I had a GSR, I got 230psi in all 4...I thought maybe it's not too accurate, but it showed me that each cylinder was pumping out about the same amount of air..
Belarus
Apr 2, 2010 03:01 AM
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
92vxjdm
Aug 15, 2008 05:05 AM
92TEGsrSC
Apr 13, 2004 12:52 PM
