compression number...
Old Mar 26, 2005 | 12:15 PM
lv6l's Avatar
Default compression number...HELP
i want to know is 180-190 for a 94 gsr with 125k miles good or bad? and i have a friend said he has 220 when he did his test on his 94 ls with 200000 miles. thanks
Modified by lv6l at 1:31 PM 3/26/2005
Old Mar 26, 2005 | 01:18 PM
cnydc2's Avatar
Default Re: compression number...HELP (lv6l)
I've seen this a couple times but can't remember what they are supposed to be. Try running a search in the integra forum for compression numbers or checks.
Old Mar 26, 2005 | 04:02 PM
95lstegman's Avatar
Default Re: compression number...HELP (cnydc2)
new for LS is 200, so 220 is WOAH. new for GS-R is 300, and your numbers are on the low side of acceptable. 140 minimum, but the really important part is the variance between cylinders. the highest and lowest can't be more than 28psi off, according to honda. but really, if they're more than 12psi or so off, your engine may be a turd.
Old Mar 26, 2005 | 05:05 PM
01BLKGSR's Avatar
Default Re: compression number...HELP (95lstegman)
According to the Helms service manual, for a GSR, the nominal is 213 psi, minimum is 135 psi, and maximum variance is 28psi.
Old Mar 26, 2005 | 05:12 PM
virusiidx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">new for GS-R is 300</TD></TR></TABLE>
i dont know about 300, but 220 is about right.
btw, did you do this at WOT? some people wont, and the numbers will come out low.
Old Mar 26, 2005 | 08:11 PM
Deluzional's Avatar
Default Re: compression number...HELP (virusiidx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx &raquo;</TD></TR><TR><TD CLASS="quote">i dont know about 300, but 220 is about right.
btw, did you do this at WOT? some people wont, and the numbers will come out low.</TD></TR></TABLE>
Actually the majority of cars ive seen were around 240 for gsrs. How do you manage to do WOT. You just crank your motor over a few times
Old Mar 26, 2005 | 08:21 PM
virusiidx's Avatar
Default Re: compression number...HELP (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">Actually the majority of cars ive seen were around 240 for gsrs. How do you manage to do WOT. You just crank your motor over a few times</TD></TR></TABLE>
yeah 240 too, WOT = wide open throttle, just make sure you have the accel. pedal pushed down all the way when cranking about 5 turns.
Old Mar 27, 2005 | 08:00 AM
lv6l's Avatar
oh i didn't do it with the wide open throttle. by the way would it make any difference if the engine is warm up, hot , or cold?
Old Mar 27, 2005 | 08:50 AM
sabotage7's Avatar
Default Re:
mine was 240 all the way across for my 94 gsr, which according to the haynes manual is good. i dunno though, cuz it sounds like people are saying that some manuals have diff specs in them. does anyone know what a honda manual actually says it should be?
Old Mar 27, 2005 | 09:36 AM
opiumdaze's Avatar
Default Re: Re: (sabotage7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sabotage7 &raquo;</TD></TR><TR><TD CLASS="quote">mine was 240 all the way across for my 94 gsr, which according to the haynes manual is good. i dunno though, cuz it sounds like people are saying that some manuals have diff specs in them. does anyone know what a honda manual actually says it should be?</TD></TR></TABLE>
some one already said it earlier "Helms" is the Honda manual
Old Mar 27, 2005 | 11:34 AM
sabotage7's Avatar
Default Re: Re: (opiumdaze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze &raquo;</TD></TR><TR><TD CLASS="quote">
some one already said it earlier "Helms" is the Honda manual </TD></TR></TABLE>
i'm talking about from an actual honda/acura service manual, the dealer one. helms is a brand, like chiltons and haynes, they all make manuals for all types of vehicles.
Old Mar 27, 2005 | 02:02 PM
sabotage7's Avatar
nevermind, i found my factory service manual
my factory manual says:
nominal=270
minimum=140
max variation= 28
my haynes manual says:
nominal=270
minimum=135
max variation= 28
and according to 01BLKGSR, helms says:
nominal=213
minimum=135
max variation= 28
see, thats what i was talking about. the varience in #s btw different manuals!
i think i'll stick with the specs in the factory manual!
Old Mar 27, 2005 | 02:40 PM
BremertonDA's Avatar
From: Bremerton, Washington, United States of America
My LS was 225psi all across, so I'd think the GSR should be higher than that.
Old Mar 27, 2005 | 04:13 PM
lv6l's Avatar
does it matter if the engine is warm up or not??
Old Mar 27, 2005 | 04:17 PM
Default Re: (lv6l)
Yes it should be at operating temperature, full throttle.
Old Mar 28, 2005 | 05:10 AM
01BLKGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sabotage7 &raquo;</TD></TR><TR><TD CLASS="quote">nevermind, i found my factory service manual
nominal=270
minimum=140
max variation= 28
nominal=270
minimum=135
max variation= 28
nominal=213
minimum=135
max variation= 28
WTF, why is mine so low
Old Mar 28, 2005 | 01:16 PM
lv6l's Avatar
what does the variation mean and how does it work?
Old Mar 29, 2005 | 05:03 AM
01blackgsr's Avatar
Default Re: (lv6l)
the variance is the difference between the compression in the 4 cylinders. All of them should be within 28psi of each other.
iTzKeviN
Oct 14, 2005 09:01 PM
Project_EK
Jun 20, 2005 12:56 PM
sshaikh01
Mar 22, 2005 10:35 AM
I fjhlllllllllllkvu
Nov 16, 2003 12:11 PM
Lei Siew Long
Jul 10, 2001 11:54 PM
