compression checked...
Old Jun 21, 2004 | 12:41 PM
  #26
91ls-v's Avatar
Default Re: My Built 4dr GSR compression checked... (Wesb18DB8)
well i did mines over and my numbers are 175, 170, 165,165
that is about right..i believe
Old Jun 21, 2004 | 01:08 PM
  #27
reno96teg's Avatar
Default Re: My Built 4dr GSR compression checked... (91ls-v)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ls-v &raquo;</TD></TR><TR><TD CLASS="quote">well i did mines over and my numbers are 175, 170, 165,165
that is about right..i believe </TD></TR></TABLE>
yep.. i believe 180 across is optimal for your engine, so, at 206k miles, you're fine.
Old Jun 21, 2004 | 06:34 PM
  #28
chrisnova's Avatar
Default Re: compression checked... (91ls-v)
I agree with some of the other posts here. Pick up a Haynes manual or some other shop manual and look under the compression section and it will tell you precisiely the right way to test your compression for that model. But basically the engine should be warm and you should have the throttle wide open and all spark plugs removed. Crank about 7 times, at least in my 1989 Integra LS manual it tells me this. The pressure should build quickly. MAke sure to disconnect the fuel pump if you don't like gasoline fumes. I got 190 183, 180, 190 after doing a head gasket job on mine. I think you want to have your cylinders no more than 15% variance, but this depends on the manual your read. DO add oil and see if the compression comes up. If it does it is likely weak rings. If it doesn't maybe a valve job is needed. Good luck
Old Jun 21, 2004 | 07:42 PM
  #29
VN712's Avatar
Those are good numbers. Don't worry about rebuilding untill it drop to abour 130
Old Jun 21, 2004 | 07:48 PM
  #30
Eviloliv3's Avatar
Default Re: My Built 4dr GSR compression checked... (B20ZLS)
i had a shitty head on my car before, my compression was 165, 165, 95, 172
i swapped out heads (with a lil work done to the head) and i got this all across the board
Only 9.6 CR too
Old Jun 22, 2004 | 08:18 AM
  #31
2chron4u's Avatar
Default Re: My Built 4dr GSR compression checked... (Eviloliv3)
i have 404's and am running 150psi across the board, used to be 210 before the cams.
Old Jun 22, 2004 | 08:39 AM
  #32
NJcoupe's Avatar
b18b1 140k miles
135 155 145 70
thats after b00st
EF9_TryMe
Oct 31, 2011 11:12 PM
davidcrx89
Jun 26, 2005 10:52 PM
Capt. Jimbo McSubipants
Feb 21, 2005 12:33 AM
mustbenu
Jan 23, 2004 12:56 PM
lothian110
Oct 28, 2003 09:24 PM
