is this a complete list for auto to manual conversion?
Old Jul 31, 2009 | 07:06 AM
Bango_Vang01's Avatar
Default is this a complete list for auto to manual conversion?
Originally posted by snwsk8r8 on Jun/29/09
I am in the process of sourcing parts to do a 5speed swap. Alot of the information on here is old or incomplete.
If there is something that i will need that is not on the list please tell me so i can add it. I would like this to be a complete list so that it will help me for my swap and others doing the swap in the future. Also feel free to recommend certain brands.
Im going to put a "(#)" if i have it along with what i got and where/how much and a "(/)" if i have not gotten it yet but i will put what im planning on getting.
(#) Transmission
Gsr
B20vtec - $450
(#) Pedal assembly - Fits from 92-95 civic and 94-01 integra
Junkyard - 25$
(#) Shift Boot
Red Stitch - Password JDM - 25$
(#) Shifter
Ebay - Megan Racing - $34
(#) Shift **** -
(#) Shift Linkage bushings - Will make shifting better
Energy suspension - 17$
(#) Manual Starter and bolts - Auto Starter won't fit
Junkyard - 35$
Starter Bolt Part# 95701-10105-08 Quantity- 1
(#) Clutch Kit -
F1 Stage 2 and Fidanza flywheel - Ebay - $263 shipped
(#) Flywheel^
(#) Flywheel Bolts - Part# 90011-PH3-000 Quantity- 8
(#) Pressure Plate Bolts Part# 90034-689-000 Quantity- 6
(#) Flywheel Cover- Part# 21351-PR3-010
(#) Flywheel Cover Bolt- Part# 95701-08016-08 Quantity- 1
(#) Auto to manual mount - You can buy this or cut and weld bracket from manual car and then use manual mount
Friend - Innovative - 50$
(#) Clutch Master Cylinder -
Junkyard - included with $25 for pedals
(#) Clutch Fluid Reservoir -
Junkyard - Came with Master Cylinder
(#) Clutch Slave Cylinder
Napa - 20$
(#) Clutch Lines - Get steel braided lines as they are much easier to run
Hondatech - Steel Braided - 65$
( /) Manual Cluster (optional)
( /) Manual ECU (optional)
(#) Shift Linkage
(#) Manual Tranny mounts
(#) T bracket
( /) Engine/Tranny Stiffener Part# 11950-PR3-000
( /) Stiffener Bolt Part# 95701-12050-08
(#) Half Shaft/Jack Shaft
What do you guys think? I got it off on T-I, just wanted to know if theres anything missing. Thanks
hondaforlifeyo
Nov 14, 2007 06:58 PM
jdmhondamotive
Sep 7, 2007 06:21 AM
stackz
Jan 7, 2007 05:02 PM
bman511
Jul 1, 2005 07:04 PM
RuthlessEF-9
16
Feb 28, 2003 11:29 PM
