cold heat!
Old Jan 20, 2008 | 08:00 AM
93ricerocket's Avatar
Default cold heat!
i think i could be a heater core but i took a quick look and couldnt find it. could this be my proplem ?or could it be somthin else .it gets warm once in a while for abought a min . any help would be nice its like 7degrees out there!
Old Jan 20, 2008 | 10:42 AM
HONDRETTI's Avatar
Default Re: cold heat! (93ricerocket)
does your temp gauge move? its most likely your thermostat
Old Jan 20, 2008 | 12:00 PM
90IntegraTuner's Avatar
funny you should mention this...i had the same problem...check three things...first, check your coolant level in your radiator...my coolant was extremely low and thats why it did not stay warm...check your hose tightness and run a pressure check on your radiator...make sure not coolant is evading...also, like hondretti said, check your thermostat and housing...this goes along with the pressure test but if any gas or pressure is escaping there, your looking at a problem here...
lemme know if you need any help!
--Dan
Old Jan 21, 2008 | 02:58 AM
33_Red_Gsr_33's Avatar
^^ yep i had the same thing happen to my girls 2000 celica nad the thermostat was the problem..
Old Jan 21, 2008 | 07:33 AM
jhammond_82's Avatar
Reject Papi
Default Re: cold heat! (33_Red_Gsr_33)
oh...my...god....me too! jk. change the termostat ftw!
Jerkface38
Honda Civic (2001 - 2005)
10
Mar 14, 2013 01:55 AM
em1effekt
22
Nov 29, 2011 04:23 PM
orange99si
Dec 9, 2006 01:42 PM
ekferio
Mar 31, 2006 10:22 AM
petrv
Apr 18, 2004 09:26 PM
