code 90
Old Mar 30, 2005 | 10:02 PM
hmongboyLS's Avatar
Default code 90
so the other day my check engine light comes on. I did the do it yourself code check and it read a code 90. i looked it up over at the team-integra.net articles and it came up as a emssions leak.
anyone know what the problem is and where should i check first? thanks.
Old Mar 31, 2005 | 02:16 AM
sp00led's Avatar
Default Re: code 90 (hmongboyLS)
P1457 EVAP leak - canister system
My ecu threw a code 90 as well. Once i took it to the dealer they were able to determine that it was a p1457 code. When you take it to the honda dealership they will be able to find out what the problem is specifically. With the code 90 there are two things it could be, so run it by and they will take care of ya. They told me that the O-ring on the evap canister needed replacing (check helms manual for diagram). After fixing the o-ring they reset my check engine light. Its only been 24 hours and no light, so im hoping that it should do the trick. Either way, its only an emissions issue and your car is in no real danger... only those stupid trees.
$50 dealership fix (parts & labor)
Old Mar 31, 2005 | 01:56 PM
sp00led's Avatar
Default Re: code 90 (redeyz)
light came back on, back to the dealership...
Old Mar 31, 2005 | 02:45 PM
hmongboyLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redeyz &raquo;</TD></TR><TR><TD CLASS="quote">light came back on, back to the dealership... </TD></TR></TABLE>
man that sucks. yeah, i wasnt to worried about it when i checked it out as an emissions leak.
floatfisher
Jul 15, 2007 04:37 PM
numotive
Aug 22, 2005 05:30 PM
IgniteTeg
Aug 8, 2002 09:26 AM
IgniteTeg
Aug 7, 2002 06:54 PM
