code 43. what does the mean????
Old Mar 30, 2005 | 07:05 PM
badboy409's Avatar
Default code 43. what does the mean????
check engine light came on for code 43? can someone tell me what to do????
Its for an 92' integra LS. also code 20 shows up for the electrical load detector. what does that mean??? what do i do???? help pls....!!!!!
Old Mar 30, 2005 | 07:08 PM
jdm_cars's Avatar
Default Re: code 43. what does the mean???? (badboy409)
your fuel supply is messed up Code 43 is fuel supply, and code 20 is IACV or Idle air Control Valve, you are probably getting weird irradic idling.
and Congratuations this is your first post.
And btw, your first post is to ask for help.
Old Mar 30, 2005 | 07:10 PM
projectTeG's Avatar
lol, myfriend was getting a code 43 and he replaced his FIT valve and his problems went away
Old Mar 30, 2005 | 07:11 PM
aznballer's Avatar
try ressetting ecu if it happens again could be faulty o2 sensor
Old Mar 30, 2005 | 07:13 PM
jdm_cars's Avatar
Default Re: (aznballer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznballer &raquo;</TD></TR><TR><TD CLASS="quote">try ressetting ecu if it happens again could be faulty o2 sensor</TD></TR></TABLE>
I dont see how the o2 sensor is related, but yeah try resetting the ecu, if the code comes back right-away you know you have a problem.
Old Mar 30, 2005 | 07:14 PM
badboy409's Avatar
Default Re: code 43. what does the mean???? (jdm_cars)
thanx for ur help... but where would the idle air control valve be located????how would i fix that???? Help!!!!
Old Mar 30, 2005 | 07:15 PM
Naruto's Avatar
Default Re: (jdm_cars)
try resetting the ecu first.....I always suggest that after pulling the code before anything else. You certainly don't want to try to "fix" something that may NOT be the problem only to run into more problems.......
djcue_530
Mar 15, 2007 08:53 AM
Mad Hatter
Nov 14, 2005 02:50 PM
drewboy
May 14, 2005 10:03 PM
Knightmare69
Sep 27, 2003 09:41 AM
