clutches
Old May 27, 2004 | 10:30 AM
LsV's Avatar
LsV
Default clutches
Are all b-series clutches interchangable? Even between hydro and cable trannys?
Old May 27, 2004 | 10:32 AM
spark plugs.
Guest
Posts: n/a
Default Re: clutches (LsV)
ls/rs/gs use the same...
gs-r/type-r use diff.
hydraulic and cable DO NOT use the same.
Old Jun 2, 2004 | 09:55 PM
gsrlkn412s's Avatar
no cable trannys main shaft is smaller in diameter than the hydro trannys, same amount of splines though; my friend found that out the hard way
Old Jun 2, 2004 | 10:01 PM
98gsteg's Avatar
Default Re: clutches (gsrlkn412s)
i belive it's the same with the jdm trannys
Old Jun 2, 2004 | 10:03 PM
LSTEG96's Avatar
Default Re: clutches (troublecodes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by troublecodes &raquo;</TD></TR><TR><TD CLASS="quote">ls/rs/gs use the same...
.</TD></TR></TABLE>
poor misguided fool. ok, true, the stock itr clutch may be different... but act, exedy and all that can give a **** what block/tranny combo u use, as far as its b series and hydro or whatever. and to prove, i have a cluthc i bought and used on my ls tranny, and now have in my gsr tranny. boo ya.
Old Jun 3, 2004 | 04:42 AM
dcb16's Avatar
Default Re: clutches (LSTEG96)
YUP, i got an itr clutch on my ls hydro... i pity da fool
Old Jun 3, 2004 | 08:51 AM
CNSK's Avatar
hydraulic and cable DO NOT use the same.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">poor misguided fool. ok, true, the stock itr clutch may be different... but act, exedy and all that can give a **** what block/tranny combo u use, as far as its b series and hydro or whatever. and to prove, i have a cluthc i bought and used on my ls tranny, and now have in my gsr tranny. boo ya.</TD></TR></TABLE>
efcivic12
Nov 8, 2008 07:40 AM
Ep1dem1c
Mar 29, 2008 08:57 PM
95civiccpdx
Jul 8, 2007 04:56 PM
unrivaledintegra
May 25, 2007 10:39 AM
