Clutch problems need help please....
Old Sep 1, 2006 | 12:21 PM
07CBR600rr's Avatar
Default Clutch problems need help please....
I just got a 94 ls about a week ago and it is my first 5 speed car so im learning to drive on it but yesterday i was driving home from work and it was acting funny when i started moving from a stop. Then later that day i got in my car to go to a friends house and i pushed the clutch pedal in and i felt it shaking badly, and i was hearing a noise from the engine bay like a grinding noise but only when i have the clutch pedal pressed in. Then i got on the freeway and it was ok, but when i got off the exit and stoped to pay the toll when i tried to get going again the car would not get in gear i had to start it in gear to get moving then it shifted fine. My friends both drove the car said it felt fine around the block but when we poped the hood we could smell the clutch burning, but the clutch is not slipping at all it still is fairly good, there is no leaks in the lines and no fluids on the pedal, so i think its my master cylinder my slave cylinder or maybe my throw out bearing but im not sure Please help!
Old Sep 1, 2006 | 03:21 PM
07CBR600rr's Avatar
Bump need help soon
Old Sep 1, 2006 | 11:58 PM
07CBR600rr's Avatar
Just an update i took the car out tonight and it drove fine but im still feeling that shaking in the pedal its not so bad when the pedals to the floor it really bad when its about 2 inches off the floor and about an inch pressed in.
Old Sep 4, 2006 | 06:53 AM
07CBR600rr's Avatar
Umm im starting to think its not the clutch at all when im not moving i cant shift into any gears at all and when i am moving its hard to shift??? need help
Old Sep 5, 2006 | 06:43 PM
07CBR600rr's Avatar
Bump really need help guys....
Old Sep 5, 2006 | 07:00 PM
lude of pre 2.3's Avatar
Default Re: Clutch problems need help please.... (94DCinteg)
i would say you toasted your throwout bearing by the vibration only when the clutch is disingaged. i would replace the slave cylinder as well while you have it apart. but they are a bitch to bleed. sometimes you have to use a power bleeder to get the air bubbles out of the hydrolic restrictor valve
Old Sep 5, 2006 | 08:45 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Either throwout bearing, or a clutch disc spring or other piece of metal on the disc came loose, or bent/broken pressure plate fingers, etc. Something is keeping the clutch from disengaging properly. Just order a new clutch kit, pull the tranny, and throw it on and it should be fine.
Old Sep 6, 2006 | 06:10 PM
07CBR600rr's Avatar
me and a friend of mine just let some air bubbles out of the bleeder valuve and its working again i think im going to have to replace my slave cylinder... thanks guys
Old Sep 14, 2006 | 08:00 AM
07CBR600rr's Avatar
i replaced my master and my slave and now its still very hard to get in gear. When im at a stop i cant get in any gear with the car running but when the car is off i can get in all gears smooth. When im driving and come to a stop out of gear i have to shut the car off to get it in gear again im starting to think my tranny is shot.
Old Sep 14, 2006 | 08:49 AM
LsTboi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DCinteg &raquo;</TD></TR><TR><TD CLASS="quote">i replaced my master and my slave and now its still very hard to get in gear. When im at a stop i cant get in any gear with the car running but when the car is off i can get in all gears smooth. When im driving and come to a stop out of gear i have to shut the car off to get it in gear again im starting to think my tranny is shot.</TD></TR></TABLE>
The problem isnt the master cylinder.. master cylinder is for your pedal brake. Its should be ur tranny bushing, or ur clutch is dead, that can be also ur gears in the tranny. ill try to find the problem
Old Sep 14, 2006 | 12:40 PM
PLAGUED_DB7's Avatar
Default Re: Clutch problems need help please.... (LsTboi)
Its your throwout bearing. pretty soon you wont be able to get in gear at all.
get it fixed asap.
Old Sep 14, 2006 | 02:29 PM
OC Geezer's Avatar
Could be the pressure plate or the gears??
Is there any grinding when you shift?
Old Sep 15, 2006 | 07:56 AM
07CBR600rr's Avatar
There is no grinding when i shift but its very tough to get it into gears and imposssable from a stop. Im thinking of just getting a b16 trans and an act clutch kit and putting it in over the weekend.
Ek_snoop
Transmission & Drivetrain
May 13, 2016 05:59 AM
meeka661
13
Jun 2, 2014 12:48 PM
BlkCivicFromTeamMNR.com
Aug 15, 2009 09:29 AM
hmongshaa
Honda Civic (2001 - 2005)
13
Apr 10, 2007 12:43 AM
PH3593A
Nov 2, 2004 03:10 PM
