CLUTCH PROBLEM
Old Sep 12, 2006 | 11:59 AM
DC5StylZ's Avatar
Default CLUTCH PROBLEM
well i woke up to go to school, got in the car went to push the clutch in it felt loose, started the car up it seemed ok. Went to put it in reverse and it wasnt pudging then i realize my clutch is realli loose. So i man it into reverse then practicly kick it into 1st. And im half way there and realize my clutch is starting to almost come back like its all ok again than and my the time im at school my car is fine clutch is solid little play, Does my car need to warm up for the clutch to fully work this cant go on much longer i cant wait for this **** every day.. Please help
Old Sep 12, 2006 | 12:03 PM
DC5StylZ's Avatar
Default Re: CLUTCH PROBLEM (hondacuraLs)
bump
need help!!??
Old Sep 12, 2006 | 12:10 PM
DC2 Mang's Avatar
check the fluid level and bleed it out
there may be bubbles in your line or your master cyinder may be going out
Old Sep 12, 2006 | 01:15 PM
hawaiiangsr's Avatar
Default Re: CLUTCH PROBLEM (DC2 Mang)
Exactly I bled mine and it worked great I was haivng the same problem!
Old Sep 12, 2006 | 02:55 PM
dtownrex's Avatar
if bleeding does not work flush out all the fluid and replace it with new!! is it hot where you are? the heat has alot to do with it acting that way too!!
Old Sep 13, 2006 | 06:41 PM
DC5StylZ's Avatar
Default Re: (slammed99gsr)
it just went from hot to cold u know how cold mornings can be in september and then my the day its like 70s
Old Sep 13, 2006 | 06:44 PM
lsvtek's Avatar
Default Re: (hondacuraLs)
im sure it is your master cylinder, mine did the same thing, or it can be your slave
Old Sep 13, 2006 | 06:51 PM
4DRDB8GSR's Avatar
Default Re: (4drlsintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drlsintegra &raquo;</TD></TR><TR><TD CLASS="quote">im sure it is your master cylinder, mine did the same thing, or it can be your slave</TD></TR></TABLE>
Agreed
Keith_B
Jan 26, 2009 07:20 PM
ai95
Jun 12, 2004 06:14 AM
OSG 97 ITR
Apr 17, 2004 10:11 AM
neogenesis2004
Mar 28, 2004 10:19 PM
91DA9
Feb 5, 2002 07:57 AM
