Clutch change problem
Old Dec 23, 2011 | 05:10 AM
cletus11's Avatar
Default Clutch change problem
I am replacing the clutch on my 98 LS. I can't get the transmission to seperate from the engine. I have all the bolts removed (starter, flywheel cover, 17mm) and the transmission mounts removed. I tried lowering the engine and transmission down but it won't serperate. Any suggestions or tips for getting the transmission off the engine?
Old Dec 23, 2011 | 10:35 AM
DirtyDA9's Avatar
Default Re: Clutch change problem
Did you remove carrier bearing on the back of the block for the drivers side axle, did you remove either of the axles?
Old Dec 23, 2011 | 02:40 PM
freaks_smk91's Avatar
Did u remoce the 2 support brackets that bolt up to the engine n tranny?slave cyliner?axles?theirs only so much **** you can forget to take off
Old Dec 23, 2011 | 02:57 PM
Dc4LsTeG's Avatar
EK9
Are you positive you have all the bolts out?
Old Dec 24, 2011 | 02:37 AM
cletus11's Avatar
I checked everything again and I remove the wrong starter bolt. The transmission started to seperate from the engine as soon as I started to loosen the lower starter bolt. Thanks for the help. Now I just have to get input shaft lined up to reinstall the transmission.
Mushroom picker
Honda CR-V & Element
Aug 13, 2019 07:28 AM
aznguy0087
Jul 5, 2007 11:22 AM
saikou
Jun 25, 2007 04:04 PM
Mercuryc2001
Nov 8, 2004 11:24 AM
jdm_eg
Jul 28, 2004 12:38 PM
