click here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lskid98 »</TD></TR><TR><TD CLASS="quote">I KNOW HOW A TURBO WORKS!!!!!!!!!!!!!!!!!!!!!! IM TRYIN TO FIND A GOOD TURBO THAT MAKES 8 PSI AND CAN MAKE 100 TO 125 HORSE</TD></TR></TABLE>
I think you should google around. There's a lot of info out there, honda-tech isn't the only place either.
i think you need to do hella research before you undertake this and make sure yur pockets are lined. almost any decent sized turbo (t3 super 60+) can make 275 whp. but not on 8 psi. its not about psi anyway, its about power output. you could be running 14 psi on one turbo and 8 on the other and be making the same power and thus the same wear. you need to learn to read flow charts to accurately guge where you want yur powerband. everyone knows the true proving ground is the 1320. hell a dyno operator could fiddle some parameters and tell you that yur stock LS is making 275 whp, doesn't mean ****.
a good turbo for that power is a t3/t04e .57 trim
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lskid98 »</TD></TR><TR><TD CLASS="quote">would it be posible to get 275 horse out of a stock ls motor. and if so would 8 psi do it</TD></TR></TABLE>
no.
no.
CRX_GUY_123
Mar 8, 2004 05:09 AM
