chirping or squeling while engine in under load
Old Sep 11, 2005 | 07:42 PM
THE LORD OF CHAOS's Avatar
Default chirping or squeling while engine in under load
Hey guys, my gsr has this wierd chiping/squeal that happens and then goes away real quick when i give it gas when the car is in gear. it is not very loud and does not happen when the car is in neutral. i changed out all the drivebelts this afternoon hoping that was the problem, but it didnt stop. my two lower mounts are torn, so i am ordering es mount inserts this week to fix that. do you think this could be part of the problem? i am at a loss. do you guys have any other suggestions/ideas what it could be? thanks
Old Sep 11, 2005 | 07:57 PM
pubestripe's Avatar
Default Re: chirping or squeling while engine in under load (fistandauntilus)
is this on a DA or DC integra? can you narrow down where the problem is coming from, like what corner of the car?
Old Sep 12, 2005 | 12:23 PM
ok sorry, this is a 98 DC, and it seems like it was coming from the driver side of the car, that is why i had suspected one of the drivebels being loose or worn out. thanks
Old Sep 12, 2005 | 12:30 PM
97tegGS's Avatar
Have you tightened them properly? Them mounts could be a problem as well. I know when I had a mount let go it would chirp when accelerating.
Its doing it in gear b/c there is a load. Replace your mounts and if that doesnt work go from there
Old Sep 12, 2005 | 04:40 PM
Default Re: (97tegGS)
ya, that is what i am thinking it might be, my two lower torque mounts are pretty bad, (sagging, torn) and that chirping is exactly what mine is doing right now when i accelerate. i already have one replacement, but i still gonna get the es inserts so this **** wont happen again. thanks
Old Sep 20, 2005 | 06:55 AM
Default Re: (fistandauntilus)
well i wanted to update this because i fixed my motor mounts this weekend with the es inserts, and while the car feels 100% tighter, i still hear that squeal. it does not happen at idle, only around 2.5k-3.5k rpm while i have it in gear and give it gas or when i am shifting in that rpm band. it is like a quick squeal or chirp. the noise is coming from the driverside of the car so i had originally thought it was belt related, but i changed all my belts and tightened them good so i dont think it is that. so i tried something different and took off each belt one at a time and drove the car up the street a bit. it turned out i only had the alternator belt hooked up and it still made that noise. could it be the alternator bearings or something going out? what do you guys think??
Herbie
Apr 10, 2019 08:44 AM
uoficowboy
Honda Civic (2001 - 2005)
Jul 20, 2015 07:19 PM
1320king
43
Jan 17, 2008 05:10 PM
sablan02
Feb 6, 2007 11:48 PM
Shake and Bake
Jun 30, 2006 07:14 PM
