Check Engine light
Old Aug 26, 2004 | 07:59 PM
Gsr94black's Avatar
Default Check Engine light
After putting my motor mount in today i put everything back together and now i have a check engine light on. I bridged the harness like you are suppose to so the light will flash to indicate what is wrong but here is the problem...the light flashes 4 times at a steady speed and on the fifth time it flashes extremly fast so i don't know if it is a MAP sensor problem or a O2 sensor...any help?
Old Aug 26, 2004 | 08:01 PM
iH8RICERZ's Avatar
Default Re: Check Engine light (Gsr94black)
you have code 41 Primary oxygen sensor heater
Old Aug 26, 2004 | 08:04 PM
1Quikgsr's Avatar
that also happened to me... what happeend was the o2 wire was rubbing against the frame where the headers are eventualy it melted and it would short out and throw that code.... i also wouldnt have vTec so make sure this isnt happening to you also Hope this helps/
Old Aug 26, 2004 | 08:06 PM
Gsr94black's Avatar
Default Re: Check Engine light (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr &raquo;</TD></TR><TR><TD CLASS="quote">that also happened to me... what happeend was the o2 wire was rubbing against the frame where the headers are eventualy it melted and it would short out and throw that code.... i also wouldnt have vTec so make sure this isnt happening to you also Hope this helps/ </TD></TR></TABLE>
I don't think it is that...but thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">you have code 41 Primary oxygen sensor heater</TD></TR></TABLE>
So basically replace the o2 sensor?
Old Aug 26, 2004 | 08:10 PM
1Quikgsr's Avatar
check the voltage first it isnt cheap oem primary is about 190 bucks.
vxtirent08
Mar 22, 2008 10:51 PM
AznInvasion
Nov 29, 2007 08:59 AM
civicsaremean
Jun 24, 2007 08:27 AM
suprategrazx
May 21, 2007 07:26 AM
jry2598
11
Sep 30, 2006 07:58 AM
