check engine light... :(
ok so i pulled my codes and found out that its 2 different problems. code 22 - vtec oil pressure switch, and code 90 - evaporative emission control system leak detected. anybody know what i need to do to go about fixing these problems?? any help with where to buy what i need to fix em?? all help would be greatly apreciated! thanks. btw its a 00 gsr
i just had that emission leak thing last week. i took it to a place and they ran some test with dye and smoke to find out where the leak is (mine was a vapor leak) so they did that, located 2 weak spots, replaced one part, and cleaned another.
564, it was 150 in tests, then they clean one part and order a new one. if you get it checked out and they say its a vapor leak, be ready to spend some, cause they gotta do that test witht he dye that cost like 90 or something
I got the same light on my car...
so I went to a shell station to get a diagnostic check. There were a couple of random mis fire codes and a p1399 ( undocumented error code ).
But the mechanic said that he was unable to find out what this code meant on my Integra 2000 LS Automatic.
Anyone seen this one?
lduque
Jun 14, 2007 12:08 PM
