check engine light?
i read codes it is giving me high voltage and 02sensor then abs light came on speed ometer quit working and the whole car died? when it was running I was getting 10.5 v out of the alt.
Well, you should first tell use the car, model, year, and ECU you are running if something different than stock.
10.5V is not enough coming out of the alt for starters.
ramz7887
Dec 3, 2003 09:44 PM
