Check engine light on
Old Aug 28, 2005 | 04:58 PM
low430's Avatar
Default Check engine light on
my vss gear stripped so my speedo stopped working and now my check engine light is on. the car is salvage so Im not really worried about it too much but will it hurt the engine to drive with check engine light on and vss broken. I seems to run okay but Idles high like 1200
Edit
Some kid told me it will burn out my o2 sensors and ruin my motor is this true?
Old Aug 28, 2005 | 05:07 PM
Lauj87's Avatar
its never safe to run with a check engine light on...you should get it checked..could be seriouse could be minor but you never know till you get it checked!
Old Aug 28, 2005 | 05:18 PM
BSP-DC2
Guest
Posts: n/a
most of the time check engines are nothing major, nonetheless have it checked out.
Old Aug 28, 2005 | 05:19 PM
BSP-DC2
Guest
Posts: n/a
I believe when your speedo gear isnt workin its going to throw a cel because the speedo isnt working... simple as that!
Old Aug 28, 2005 | 06:31 PM
projectTeG's Avatar
if you dont mind having the cel, just keep a check on it to make sure that the ecu isnt throwing a new code.
prwittman
Jul 13, 2018 01:00 PM
NewEra
Jul 20, 2009 08:13 PM
keegur
Acura TSX
Jan 10, 2009 01:33 PM
90civicSiRacer
Oct 1, 2007 02:35 PM
jamzm101
Apr 2, 2007 12:00 PM
