Check this.
Old Nov 19, 2002 | 12:30 PM
976's Avatar
976
New User
Default Check this.
"SIR2 B16, Tanabe Hyper, Akimoto, JDM Headlights, Neuspeed Race, Sony CD Player, White Gauges, Short Shift, Brembo Rotors, Si Wheels or Gunmetal Rota Slipstreams. Needs Paint, some bodywork, and has small electrical problem. Car runs rough, needs TLC. MECHANICS SPECIAL. Price Negotiable."
153K on body, and asking $4000.
I have been looking for a 92-95 hatch for ever, I have been jerked around everywhere. I have $4000 in cash next to me, should I just offer 3,200 or something and rebuild the motor. The SIR2 b16 swap need modified motor mounts correct? What is the stock or curb weight. (Search might help, anyway, just give me input!) I've always looked the integra, but should I even waste my time with this bitch?
Old Nov 19, 2002 | 01:03 PM
Ferrell's Avatar
Default Re: Check this. (w00t!)
offer 3k, if not search elsewhere.
Old Nov 19, 2002 | 01:16 PM
976's Avatar
976
New User
Default Re: Check this. (Ferrell)
Talked to the guy. I did a carfax, everything is clear. Except odometer roll back, which must be the sir2 swap. Anyway, he said the car runs, but dies due to poor fuel pump. Wired fine with no CEL. I might need to change the fuel pump once I get there? Or loose wire in pump? Do you thinK with bad pump, needs 60K tune-up soon, and the problems such as minor body work worth $3,000? I do, I just need your honest input.
Old Nov 19, 2002 | 03:35 PM
IntEGNYC's Avatar
the mechanical could lead to other things under the hood needing replacement. The car dying after an engine swap sounds like trouble.. and probably costing more than $4k in aggrevation. I'd pass if i were you.
My two pense.
Old Nov 19, 2002 | 03:53 PM
976's Avatar
976
New User
Default Re: Check this. (IntEGNYC)
If it is just the fuel pump, and only pay 3 g's or so. Then I think I might go with it. Stock pump a good idea for sirII b16 in 2 gen? TIA
Old Nov 19, 2002 | 04:48 PM
skeeter's Avatar
go buy a stock one.. no fun buying a built car
Old Nov 19, 2002 | 05:13 PM
Colin's Avatar
thats a tough one. i'd probably pass on it. mainly because it might not be as simple as replacing the fuel pump. that might not even be a problem, and there may be otehr mechanicl things you'd have to deal with. If you could get it for $3000 though it would be tempting. I mean if you ended up not being able to fix it you might even be able to part it out for close to that much.
no, the b16a did not need modified motor mounts to fit in the G2. all b series motors just drop right in with the stock G2 motor mounts. curb weight is about 2500-2600lbs depending on the trim level.
Old Nov 19, 2002 | 06:31 PM
ActionJackson's Avatar
Default Re: Check this. (91IntegGS)
i'd pass
Old Nov 19, 2002 | 07:27 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
My two pense.
I would be more worried about the car dying without a motor swap.. if the car dies because of the motor swap then he prolly did something wrong in the swap or didnt replace a part he should have.. swaps are not hard to do.. but they can be complicated if you forget or mess up 1 thing.. its your call man.. you can get a good lookin 92 - 93 hatch for 4000..
Old Nov 19, 2002 | 08:12 PM
976's Avatar
976
New User
Default Re: Check this. (Hatchy-Ownzjo0)
ttt
Old Nov 19, 2002 | 09:12 PM
specie's Avatar
Check it out and see what the problem is. I'm usually more concern with body work. If you can go and see it. I have no problem buying cars that's already modded, it saves you some money. But you have to make sure it's something you can work with or fix.
Old Nov 19, 2002 | 10:27 PM
Armed Ferret's Avatar
Default Re: Check this. (specie)
DA's make me feel kinda funny. Like when we used to climb the rope in gym class.
if you can, go test drive it. offer 3k, if he says no, go find one on ebay for 3k.
Keenor
Sep 15, 2010 07:39 AM
bmilt*336
Jan 28, 2007 04:52 PM
89efhatchcrap
18
Jun 20, 2006 10:07 PM
accord91h22
Jul 22, 2004 06:32 AM
91hondacrx
Jan 5, 2003 10:54 PM
