ASR subframe Brace: for those who have it, i have some questions.
just got a quick question about the ASR DC subframe brace.
for those who have it, did you have to drill any new holes or having to remove any welded on bolts like the beaks kit? i know the beaks kit, the holes do not line up and you have to drill a new hole or make one bigger.
i have the beaks kit right now and im about to install it, but then i thought about getting the ASR kit which looks a lot nicer and if there isnt any modification needed, i might just sell the beaks kit and get the ASR.
can anyone help me on this?
Will you make something up for me please?
Re: ASR subframe Brace: for those who have it, i have some questions. (RicharDC4)
This is what user JOEY F. said about it in this thread: https://honda-tech.com/zero...age=1
Seems to be lots of good info in it. Do a search on "asr" and 3 good sources come up. It appears that no drilling is necessary.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOEY F. »</TD></TR><TR><TD CLASS="quote">ASR all the way. Ive had my kit for about 4 months now and the sway bar setup works well. The great thing about the kit is it uses mostly all Honda OEM parts for the links, bushings, etc.
Also, if you want to switch from the ITR rear sway to say...a Mugen rear sway or any other brand that makes ITR specific bars, you can. (Provided you get the matching bushings.)
Re: ASR subframe Brace: for those who have it, i have some questions. (shamoo)
if no drilling is necessary then that would be awsome!
thanks for the response!
I have the ASR brace and I had to use a drill to make some holes bigger. For me I'm never going to put back the original sway bar so I don't mind.
Re: ASR subframe Brace: for those who have it, i have some questions. (SargentNg)
do you know if they are the same holes you had to make bigger the same holes for the beaks kit?
i want to install my beaks kit now and buy and intall the ASR later when i get some money. but i dont want to be dirlling too many different holes if they are different yenno?
808State
12
02-03-2004 10:55 PM
