Changing sun roof cover question
So I have a 01 integra sedan and it originally came with the tan interior, I have started the process of changing everything to the gray or black interior as I'm doing a type r conversion The sunroof cover remains tan and I don't know how to change that cover? Is there anyway to change the cover alone or do I have to change the whole sunroof as is from a donor parts car? Is there maybe a paint or spray or something I can change vet it with so I don't mess with the sun roof?
Re: Changing sun roof cover question
if I have to take down the whole sunroof assembly I might as well put the sunroof with the gray cover already up from a donor car, I am trying to see if there is any other way I can just change the sunroof cover by itself without taking down the whole sun roof. I guess I'm more worried about there being any leaks when I put the sunroof back up
The sunroof water tray is stamped out of a single piece of steel so the only place leaks are a concern is at the 4 corners where the drain lines connect to it, as long as you're careful to put the clamps back on the drains though you shouldn't have a problem. If you're worried about it you can put a bit of RTV on the nipples though.
I looked at this briefly and didn't see any easy way to change only the cover but I abandoned the planned mods when I recently decided to sell it...
If you are looking to change color on interior trim or panels I highly recommend "SEM" brand products. It is high quality stuff that can produce a very nice finish if you take your time and, of course, do all the proper prep work. ALWAYS follow directions and prep VERY WELL. Also, I like that amazon can have them at my door quickly and easily...
SpiceyRice
02-12-2005 07:13 PM
