Changed Cluster Need Help Please
Ok, I bought a GSR cluster from someone here on the boards. I plug the cluster in and the Fuel Guage rises beyond full and then drops below empty. The SRS light is on and it stays on. All of the other guages work just fine. Speedo and Tach and Temp work correctly. I have taken the Positive battery terminal off and for 1 hour and put it back on. The issue is still present. Please help if possible thanks.
OK, I changed the film and put the screws in the exact location that they were previously. Now the Abs light is on and the door indicator is on, the fuel lis correct. Do I need to reset the car again?
[Modified by dabrown, 2:59 PM 3/1/2003]
Alright I drove the car to get gas to make sure the guage was good to go. The door light finally turned off. However the ABS light is the only thing that is wrong. I performed a search and found 15 topics on ABS. Not one explained how to reset the ABS light. Any suggestions would be great thanks!
well u might want to consider the notion that its supposed to be on...meaning theres a problem...i remember onmy old toyota, when my brake fluid was low my light came on....but when i changed my cluster i didnt have light problems...i just had bunks gauges
There is only one bulb behind the abs light that I removed and the light is still on. Would you mind telling me which bulb is for the ABS? Thanks
Ok, I will post this info so if someone makes an attempt to duplicate this swap. I had to take the guages out of the GSR cluster and place them inside of the LS housing. I used the GSR film on the LS housing, however there is a clip with an Arrow on it on the back off the case. I used the LS clip on the GSR film. I am not to happy about having to disconnect the Yellow clip for the SRS so that's why I used the LS housing which allows you to remove the light bulb for the ABS. Now everything is running well for now. I would like to invest in a diagnostic tool to find out why the ABS light came on when there was nothing wrong previously. No the ABS long buzz does not exists. Thanks for your help Dan I appreciate your responses..
Integra4lyfe069
Sep 15, 2009 03:52 AM
AW
Feb 15, 2005 08:11 AM
