Central Locking Issue
Hello guys and gals,
I wonder if you can help. The central locking on my 96 Spec JDM Type R DC2, is acting up. When I use the key in the drivers door, it will only lock the drivers door, it should lock the passenger side too.
If I use the key in the drivers door to unlock the car, both doors will unlock. It seems to be an intermittent problem as sometimes it will lock both doors.
I've replaced the central locking ECU, with a good used one, and also replaced the passenger side actuator with a brand new OEM one. Still no dice.
Tom
Tom
I think that is how it is supposed to work, that is how my 95 LS locks work
unlock driver door with key, passenger stays locked
unlock pass side with key, drive door is also unlocked
Thanks. It used to lock both doors, so something is wrong. I think I'm going to source a used switch for the drivers side, as it's the only component I haven't replaced.
breckrider
Honda CR-V & Element
Jan 29, 2018 02:22 AM
